-   -   lifting points on 911sc (http://forums.pelicanparts.com/porsche-911-technical-forum/246850-lifting-points-911sc.html)
82911sc 10-19-2005 07:27 AM
Where is the best place to place hyd jack or hoist pads on a 911sc
Dan
yelcab1 10-19-2005 07:52 AM
Under the engine, just a few inches behind the tran/engine mating point, and only to lift it up in order to place jack stands under the torsion bar covers.
There are access ports on either side of the car (square, covered by plastic) that you can insert a jack plate and use the jack on the plate.
Other than that, I also used a 1 inch thick of hard wood over the jack, place the whole thing under the body at a nice stout place in front of the suspension for jacking up the car.
AES 10-19-2005 10:12 AM
There have been pictures posted of this, have you done a search?
82911sc 10-19-2005 10:32 AM
yes but cant seem to find the right search terms . I have tried jacking points, lifting points ,jscking up 911 etc.
Dan
Bill Verburg 10-19-2005 01:13 PM
I just did a search on "jack and point"
and got these 2
#1
#2
"jack" gives
#1
#2
there are a lot more
82911sc 10-20-2005 04:24 AM
Thanks a lot .
Dan Johnson
