How Do You Support Your Car
when you are working underneath it? Am I being too concerned about using jack stands?
I am considering this
Thanks, Tom
Old 08-12-2005, 05:05 PM
Jack stands under the torsion bars in back and under the front of the control arm mounts in front. Gently push on car in all directions to measure stability. Then place wheels (the ones you took off) under the car for added protection.
1980 911SC Targa 3.6L
Old 08-12-2005, 05:08 PM
CBRacerX's Avatar
jack stands plus a nice hefty snap-on floor jack
Chris
https://dergarage.com
‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900
Old 08-12-2005, 05:27 PM
Administrator
Jack Olsen's Avatar
A low-rise or mid-rise lift will be much more useful than ramps.
73911guy's Avatar
I've looked at the ramps a lot, thinking these must be an inexpensive way to get under a car. Then I see the prices, and see that a mid-rise lift is in the same ball park. Mid rise lifts suddenly don't look as expensive!
Jim
Old 08-12-2005, 05:36 PM
VFR750's Avatar
I have used the jack stands under the front torsion bar mount, and the rear torsion bar cover many times. The car spent last winter that way. Very stable. no concerns.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 08-12-2005, 06:28 PM
pgrunwald's Avatar
How do I support my car?
I have to go work in a corporate office with many unpleasant people, policies, and procedures and they make me do it 50 hours week in and week out...
2006 Boxster
'87 Carrera Targa"Crystal Blau" (gone)
Old 08-13-2005, 01:05 PM
Zeke's Avatar
That's what I thought the title meant, too. Currently, my car is un-supported. Maybe the PO could make an alimony payment.
The only way you would want something like those drive on ramps is if you wanted uner the car with the suspension loaded. Seldom will that need arise unless you do alignment. And then, the ramps would not provide the features you need most, like floating wheel pads for making adjustments.
Old 08-13-2005, 02:34 PM
Stranger on the Internet
patkeefe's Avatar
Under the TB covers or the tube in the rear.
Like the picture in the front. I don't want to screw up the alignment of the Elephant bushings in the front by using the front TB cover plate, but I do occasionally. and try to take the load on the bolts.
Patrick E. Keefe
78 SC
Old 08-13-2005, 02:53 PM
Bill Verburg's Avatar
Jack stands work nice
midrise is nicer
Bill Verburg
Old 08-13-2005, 03:58 PM
randywebb's Avatar
I don't see the snow blower....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 08-13-2005, 05:26 PM
I'm with Bill
Rick V's Avatar
hell I'm a mechanic. I use a 9000lb. lift Sorry
Old 08-13-2005, 05:29 PM
pgrunwald's Avatar
Can you drop an engine with a midrise lift or do they extend to far back?
Thanks,
Paul
2006 Boxster
Old 08-13-2005, 06:03 PM
