cantdrv55's Avatar
How do the guages come out of the dash?
I tried to remove the oil guage last night so I can get to a relay back there but I as afraid I'd scratch up the dash. Does the rubber lip around the base of the guage need to be pried off the bezel before the whole thing pulls out? How'd you go about doing this?
Old 10-20-2005, 08:12 AM
Work in Progress
Rich76_911s's Avatar
I just twisted and carefully pulled it out. I don't think there is much more too it.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 10-20-2005, 08:16 AM
drag racing the short bus
dd74's Avatar
Twist off. Like a fine beer...
Old 10-20-2005, 08:17 AM
or, you can pop the hood and push the thing out from the back. Sometimes pulling from the front is really difficult.
Old 10-20-2005, 08:28 AM
Reach from the back and push. That is much easier. There are no spiders back there so don't be afraid.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-20-2005, 08:34 AM
wcc wcc is offline
wcc's Avatar
I just did this and I found it easy by using a very stiff putty knife. Just this week I changed all my gauges from black to white. I started by sliding it up under the metal bezel from the bottom while gripping the top of the gauge. I pried a little on the bottom then pulled from the top. As it started to loosen up I started to wiggle it side to side to. Then it came right out. The rest of the gauges come out even easier cause you can reach in and push them out without any problem. The rubber part will slide right off the back once the gauge is out.
Don't forget to draw a picture for yourself to where the wires go. I actually found this to be more helpful than all the pictures I took.
That's about it.........
GOOD LUCK!!!!!
Bill
'85 Carrera
Old 10-20-2005, 08:43 AM
GFCC
Jeff's Avatar
When you put the gauges back in use windex or similar as a lubricant on the rubber O-Ring. This will insure that the O-Ring doesn't bunch up.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 10-20-2005, 08:53 AM
cantdrv55's Avatar
Thanks guys. Yelcab, how'd you know I'm afraid of spiders?
Old 10-20-2005, 01:33 PM
dkm_chgo's Avatar
My clock is loose. How do I get it back in securely?
'72T Targa w/2.2S MFI (sold circa 2010)
Old 10-20-2005, 04:59 PM
Or you can go for a boot with the hood not down all the way and they will all pop out,ask me how I know.
Old 10-20-2005, 05:09 PM
Jack Gresham's Avatar
I use a small plastic putty knife.
Jack 87 Carrera
Old 10-20-2005, 06:21 PM
Once you get one out you can push the others out from the back. May have to take the wheel column plastic off for the speedo and tach.
Funnyguy
Old 10-20-2005, 07:46 PM
wcc wcc is offline
wcc's Avatar
I have a '85 911 and I got all the gauges out without removing the steering wheel or anything else. Once I got out one gauge you can push out the next one and so on. The Tach was a very tight fit between the dash and the plastic but move it slow as you work it and it'll come out no problem.
Bill
Old 10-21-2005, 03:50 PM
limble's Avatar
Put duct tape on the putty knife so you don't scratch the dash.
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 10-21-2005, 05:26 PM
