Kanipso's Avatar
?? Fuel pump bad. Suddenly very noisy..
After driving the car all day, I stopped for gas. When I started it after putting $20 or so in (3 gal) : ( ... The fuel pump was very loud. Almost a grinding sound.. Pressure is still ok. (yes I have a guage installed)
This is all after a CIS to EFI conversion that went smoothly.. Could the new fuel regulator setup have added new stress to the pump causing it to go out quicker? It's set at 2.5bar..
I have also noticed the smell of gas recently.. Thoughts?
Old 10-18-2005, 05:45 PM
Lots of junk in the gas these days..I guess stations let the levels drop lower than normal before getting a tanker in. My MFI fuel pump quit last week. I took it apart and a fair amount of crud was in the impeller, cleaned it up, resealed and itseems to work fine now.
There have been several threads on fuel pumps with the general thought being that a dead headed high presure pump is goiung to be working under a lot of stress.
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 10-18-2005, 06:19 PM
beamonk's Avatar
Send a message via AIM to beamonk
Try a new filter, sometimes it will help
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 10-18-2005, 07:18 PM
Kanipso's Avatar
It has a new filter on it now, less than a week old. I did some reading in 101proj. book. It says in there that when it gets noisy it's a warning of complete failure.. Isn't there a screen or something on the intake side of the pump? I would hope so. Who knows what's in the bottom of my 23yr old tank.
Any thoughts on the fuel smell??
Old 10-19-2005, 02:21 AM
beepbeep's Avatar
CIS pump works @ approx. 7 bar system pressure. Your pump now works @ 2.5...it might be overspeeding.
Thank you for your time,
Old 10-19-2005, 03:24 AM
Early_S_Man's Avatar
Porsche Crest
A good indicaton of the pump health could be obtained by measuring the current drain of the pump. If it is approaching 8.0 Amps [the limit per the factory spec book] ... you may need to change it [for good measure] to one more suitable for EFI system pressures.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-23-2005, 04:32 PM
