-   -   Where is my oxygen sensor ? (http://forums.pelicanparts.com/porsche-911-technical-forum/248343-where-my-oxygen-sensor.html)
livi 10-29-2005 12:06 AM
Correct, Randy.
Thats why a lot of my baby patients have a hard time breathing when they are hit by the R (enn) S (port) virus. ;)
Obviously my euro car does not need neither a cat, nor an oxygen sensor.
All this emanated from me contemplating SSI. Donīt know if it will improve power output that much on my 3.2 though.
randywebb 10-29-2005 11:24 AM
there are good data out there re the SSI on a 3.2L motor... not sure but IIRC it doesn't help much unless you get a different chip -- then there is the hp/$ factor too
Search and I'm sure it will pop up... or maybe someone that knows will post the threads
Wil Ferch 10-29-2005 12:50 PM
This still is not stated clearly here.... although some have touched upon it breifly.
Yes...USA and certain other cars used a cat, and O2 sensor for emissions.
Yes..."most" ROW or euro cars had no cat and no O2 sensor. DME did not process a closed loop signal for these cars.
But...some Euro and/or ROW cars were delivered with cats ( hence with O2 sensor) to allow running with unleaded fuel which gave some owners a tax break. These were close to USA in how the DME functioned.
So.....can't say all ROW cars didn't use or need O2 sensor .
Tech/spec books will identify which Euro type you have by the engine "type" number 930/XX.
- Wil
livi 10-29-2005 01:57 PM
Thanks, I will take a look in the original manual and compare with engine no.
BTW, after extensive reading of previous threads I have decided against SSI and I am currently very interested in a SW chip instead. ;)
