22mm strut mount nut
Holly Cow, .
I can't believe how hard it is to find a supplier for these. Anyone have an Idea on where to find these without having to buy in bulk. Local Ace hardware and Napa Autoparts didn't have any this big.
99 supercharged Boxster 1977 911 race car - gts (sold) ![]() Spec 911 Racing Porsche Racing Club |
Schleprock
I got mine from McMaster Carr www.mcmaster.com (M14 x 1.5 plain zinc) but had to buy 10. Hint- I have extras. You can get them thru Pelican i'm sure too.
You can reuse these, even though you're really not supposed to reuse nylon-insert lock nuts. They still resist loosening when reused. The tab washer beneath the nut also helps lock the nut onto the shaft and wouldn't you know, it's not supposed to be reused! If you can re-bend the tab washer (also called a lock plate), then you can reuse it. Heck, you can bend it in a new place if you want to!
Kevin L '86 Carrera "Larry" |
Outstanding. That is exactly what I need.
Schleprock
So you gonna reuse 'em, or you want two new ones from me?
I'll reuse'em, but thanks for the offer.
tc
