nippondenso rebuild post
I remember a post long ago by Rod Walter the pca lincoln trail region on nippondenso a/c compressors. I have a spare for my 87 carrera and want to try to freshen it up over the winter. does any one have the part #'s for a service/ rebuild. I have a source for denso/ nippondeso parts at dealer cost and would share my IN.
thanks keith epperly
87 slant nose turbo look carrrera cabrioet
Old 10-28-2005, 11:13 PM
Keith - I think that same article is in the tech info center here. Don't know the part numbers but there is a shaft seal kit, and an o-ring/valve reed kit. I got mine from ackits by giving the compressor model number. Ken
Old 10-29-2005, 08:28 AM
Used Up User
imcarthur's Avatar
Just to divert a bit . . .
Mine's leaking at the shaft & I plan to rebuild this winter. Is it safe to assume there is no refrigerent left? Can I just unbolt & walk away or does that kill baby seals or something?
Ian
'87 Carrera Cab
Old 10-29-2005, 09:39 AM
To double check just take a small screw drive and depress the schrader valve like you were letting to much air out of a tire. If its got freon left you will know. Then if it does maybe someone will evacuate it for you and save the freon for when its time to refill.
Keith Epperly
Old 10-29-2005, 09:52 AM
Used Up User
imcarthur's Avatar
Thanks Keith
The pressure valve that's circled? Or the suction valve?
Ian
'87 Carrera Cab
Old 10-29-2005, 10:02 AM
Used Up User
imcarthur's Avatar
Keith
Answered my own question. Yes it still has refrigerent.
For seals, I found this:
Polar Bear Inc
and this:
acsource.com
Ian
'87 Carrera Cab
Old 10-29-2005, 11:03 AM
scottb's Avatar
Rebuilding a Nippondenso compressor.
1984 Targa
Old 10-29-2005, 11:10 AM
Thanks to everyone that chimed in on this thread, I just ordered
the gasket set and shaft seals from AC Source.Com for $28.04
including freight.
Thanks again
Keith Epperly
Old 10-29-2005, 11:51 AM
Used Up User
imcarthur's Avatar
Keith
Which seals did you order? Since I'm going to be doing the same . . .
These?
'87 Carrera Cab
Old 10-29-2005, 12:07 PM
I ORDERED BOTH SETS ITS SO CHEAP, ONE OF THOSE WHILE YOUR IN THERE DEALS AND I WON'T FEEL BAD IF I JUST THROW SOME AWAY!!
KEITH EPPERLY 87 SLANT NOSE TURBO LOOK CARRERA CABRIOLET
GUYS WAIT UNTIL I CAN POST THE 68 EL CAMINO PHOTOS, I KNOW ITS NOT A PORSCHE BUT IT IS A JOY THAT I WAS ABLE TO DO A FRAME OFF IN LESS THAT 2YEARS. NOW I WANT TO MAKE MY 87 3.2 INTO A 3.4 AND ANYONE HAVEING PARTS EMAIL ME.
Old 10-29-2005, 09:21 PM
I bought the rebuild kit this summer. The rebuild was fairly simple. I also decided to replace all the o-rings in the system with the green nitrile(?). This was to be certain that my system was leak free. Replacing these orings was worth it as many of them looked bad. Might consider that as my o-rings were 20 years old.
86 911 coupe
2001 VW TDI
Old 10-30-2005, 04:04 PM
