-   -   H4 Adjustment Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/248571-h4-adjustment-problem.html)
MAS956 10-29-2005 09:52 PM
Now that I have a working headlight switch, I decided I should adjust the beams properly. As I was turning the up/down screw to raise the level of the beam, the internal assembly just flopped forward and I was unable to adjust further.
I removed the headlight from the bucket, it was immediately apparent what the problem is: The rubber grommet that the adjusting arm "plugs" into was shreaded and not holding the adjusting arm in place any longer.
Does anyone have a source for these replacement grommets or found a satisfactory substitiute? I'm dead in the water for night time driving until I fix this.
Thanks,
Early_S_Man 10-29-2005 10:23 PM
Mark,
I don't remember the exact size, but, a high-quality fuel hose will work if you cut it to the correct length. It should be snug in the 'sheet metal' before pushing in the adjuster link.
MAS956 10-29-2005 10:40 PM
Thanks Warren,
I'll give that a go.
k9handler 10-30-2005 01:32 AM
or...post (PM) your mailing address and I will send you two of them as I have an old H4 I use for parts.
MAS956 10-30-2005 09:20 AM
H.D.,
Thanks for the offer...PM sent.
