H4 Adjustment Problem
Now that I have a working headlight switch, I decided I should adjust the beams properly. As I was turning the up/down screw to raise the level of the beam, the internal assembly just flopped forward and I was unable to adjust further.
I removed the headlight from the bucket, it was immediately apparent what the problem is: The rubber grommet that the adjusting arm "plugs" into was shreaded and not holding the adjusting arm in place any longer.
Does anyone have a source for these replacement grommets or found a satisfactory substitiute? I'm dead in the water for night time driving until I fix this.
Thanks,
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 10-29-2005, 09:52 PM
Early_S_Man's Avatar
Porsche Crest
Mark,
I don't remember the exact size, but, a high-quality fuel hose will work if you cut it to the correct length. It should be snug in the 'sheet metal' before pushing in the adjuster link.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-29-2005, 10:23 PM
Thanks Warren,
I'll give that a go.
Mark
'82 SC Targa (RIP)
Old 10-29-2005, 10:40 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
or...post (PM) your mailing address and I will send you two of them as I have an old H4 I use for parts.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 10-30-2005, 01:32 AM
H.D.,
Thanks for the offer...PM sent.
Mark
'82 SC Targa (RIP)
Old 10-30-2005, 09:20 AM
