Quick question, oil check..
Hi!!
When starting a 911 from 1988 from cold, how long do I have to wait before I can check the oil?
Do I have to drive the car for awhile, or is it enough to have it idle for a minute?
The manual says that I'm supposed to idle the engine for 30 seconds, but it doesn't say wether this is after a long drive or not..
Thanks!!
Old 11-04-2005, 03:20 AM
a.k.a. G-man
Geronimo '74's Avatar
Engine has to be at operating temp, I believe
Put it on a level surface before you check
Old 11-04-2005, 03:24 AM
ok thanks..
so basically it's ok to check the oil after driving for a few hours?
Old 11-04-2005, 03:28 AM
a.k.a. G-man
It should have reached operating temp let's say after 20 min or so, depending on the outside temp.
So after a few hours of driving, you should be ok.
Just let it rest for a minute on a level surface, then check oil
Old 11-04-2005, 03:32 AM
OK, thanks a lot!
Old 11-04-2005, 03:42 AM
durn for'ner
livi's Avatar
Like mentioned, drive it till the oil temp gauge has stabilized and does not raise anymore. Depending on outside temp it takes around 20 - 30 minutes. Park on level ground and let idle for a minute or two till oil level gague is stabilized. Now take your measure. Aim for mid marks on stick (which equates to around 3 o´clock on my gauge).
Note that even a slight engine "under temp" will lead you to believe you are low on oil when checking the stick (and gauge) - possibly resulting in overfill.
Markus
Resident Fluffer
Carrera '85
