Thumbs up need help
i have a 1979 porsche 911 coupe and the problem is i smell gas inside the car, its comming from the engine compartment i look and didnt see any gas dripping anywhere any clues where it can be comming from thank you for the help guys.
sylvester
Old 11-01-2005, 03:07 PM
Tom '74 911's Avatar
Check this link:
Fuel line question
I dealt w/a fuel leak recently and it was here and easy to fix. A good way to check - turn the key, but don't start the car, so the fuel pump starts running, pressurizing the line. Then start crawling around underneath your car, looking for the leak! I could see mine from w/in the driver side rear wheel well.
Good luck,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 11-01-2005, 03:29 PM
