-   -   Replace Grommet after A/C Removal with solid plug? (http://forums.pelicanparts.com/porsche-911-technical-forum/249453-replace-grommet-after-c-removal-solid-plug.html)
VFR750 11-03-2005 03:45 PM
I'm getting ready to pull the A/C from my 82SC. I have looked at a drawing that says there is a rubber grommet that seals the line running from the rear condenser to the front condenser, to the chassis. Porsche part number 901.573.143.00.
Once the line is removed there will be a hole in the grommet. And a hole in the chassis.
Is there a proper Porsche grommet, without a hole in it, (aka, a "plug") to seal the chassis?
I imagine the hole may have existed in cars prior to the factory making A/C standard, but I can't find any reference to a chassis plug.
Fishcop 11-03-2005 06:20 PM
I just went to a local place that specializes in rubber extrusions. They had hundreds of various rubber plugs and grommets... You should plug them to keep "things" out.
