whose chassis? Tyson or a 911??
Senior Member
Mr. Schmidt, you should be in engineering school. It'd be a breeze for you, you'd meet a lot of smart ladies, you'd raise your income ceiling considerably and you'd get to work on exciting design projects.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Licensed User
One thing he will not do in engineering school is meet a lot of ladies
PRO Motorsports
Well, I mentioned that earlier. I do exactly that, but only on coil-over cars. Since the main goal here on the torsion bar cars is increasing chassis rigidity/ torsional stiffness, the angled piece is much more effective in reducing twist, which is the most beneficial to handling. The bottom gusset came about from seeing many cars that were heavily tracked that were splitting the seam in that area. I would seam weld them back together, than add in the gusset. (In addition to the upper pieces) Big improvement in feel. The client always comments afterweard how much tighter and creak/flex free the chassis is when it's done.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
PRO Motorsports
PRO Motorsports
I just got this joke!
![]() i've got more... trade 'ya for narrowbody eeevil setup secrets
dave 1973,5 |
PRO Motorsports
I could PM you some info on how to fit 245's on 944Turbo 8's in the back of a narrow body. But you have to promise not to tell anyone.
now *that* would be cool. would those fit in the front too?
(i'd tell no one and pretend that i'm naturally quick )
dave 1973,5 |
PRO Motorsports
Sent you an "Evil" PM.
SSSHHhhhhhhhhhh..........................
Awesome, Tyson. Maybe something similar for the Cab reinforcements? I didn't miss that, did I?
Cheers,
Andy |
PRO Motorsports
But the ones I had done in the front on Scruffy at one time just aren't that feasible for most people. That's part of the reason I removed them. That, and rules.
I would rather be driving
I have seen Scruffy and know these work. thanks for the very nice detailed explanation. HMM 245 on 8s on a narrow body. My newly painted SWT could look quite evil that way...
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Tyson - what are your thoughts on spot welding in between the spots where the factory welded on the eqarly cars unit body. Would that be valuable to do?
Let's say we break the candidates for this down as: 1. Street only coupes 2. Street only targas, cabs 3. Street/Race as above with cage. 4. Full race - cage assumed
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
PRO Motorsports
I'd recommend seam welding rather than spot. But to answer your question:
1. street only coupes: yes on '71 and older, as these are the flimsiest. '72 and newer are strong enough for street duty. 2.street only Targas and cabs: yes, all years, they need all they can get. 3.street/race w/cage: yes, all years, the cage puts new stress in new areas. 4.fullrace/cage: absolutely, and gussets at every joint/weak point. Not a bad idea on #3 either.
PRO Motorsports
Details on Scruffy's chassis reinforcements (Please, Tyson?) TIA!
Andy |
Sports Purpose 911 Driver
I took the car to work today. still so cool to drive a car as tight as a coupe (nearly) and then put the top down for the ride home. engine is starting to come into its out. and the RSR improvements Tyson added in the engine compartment make a BIG difference!
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
"I'd recommend seam welding rather than spot..."
- I thought doing the entire seam caused too much heat "migration".... ?? Thanks for all your help and advice!
Bill G. '68 911 Ossi Blue coupe |
