Correct method to plug/remove smog Lines
I m doing the SSI back date on my 79SC.
I have been spray the barrel and copper nuts on the stock headers for a week with pb Blaster. All six copper nuts came free of the studs with minimal torque. YEAH since I dont have the long hex for the barrel nuts that will have to wait for tomorrow. Again PB is great stuff. When i looked at the way the HE's were rusted out I thought I was going to have major problems. But I got lucky. I do need advice on how to remove and cap the smog lines??? the 3 metal smog lines going into the block loosened up with a 17mm flare nut end wrench YEAH again.... now what type and size of bolt?/cap nut? should I use to plug the holes in the block.Are these actually tapped ? I'm not sure if a std metric or stainless bolt should be used?? what size ?? Any issue with alum block and a steel bolt i should be aware of?? Waynes 101 book doesn't cover it , the Bently doesn't I dont think , so I am conting on you guys . Thanks
HB Kramer (4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete) (2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well. |
hbkramer,
This is what you want. They have the correct thread size, and they are inexpensive. If you get the cheap hardware store imitations in ASE threads, you will damage the threads in your head. Maybe that's not important, but why ruin a thread forever? PEL-BRC-02 Rex
1975 911s 1997 Saab 900s |
Plugs for air injectors.....
HBKrammer,
I did exactly last year what you're doing. Call PelicanParts and ask for Tom Gould and he'll help you get the right plugs. Remove the air lines and injectors from the engine block. Very simple task. If you need more info, contact me at ATD911@hotmail.com. Good luck...... Tony |
What should the plugs be torqued to?
Great info Tony.Rex !!! Thank You !!!!
I cant wait to get all the extra baggage out from the lower engine bay... NO MORE smog lines NO MORE hot running Cat NO MORE rear mounted oil line And best of all... NO MORE scraped knuckles when adjusting the valves I will order the block plugs today. Rex how in the world did you find these???absolutly invaluable and I dont mean vodka.
Re: Correct method to plug/remove smog Lines
You can also get short 10mm allen head set screws to plug them from a metric hardware supply house. That's what Wayne shows in his engine rebuild book (not the 101 projects book.) TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
