Stereo install help
Hi Everybody!!
I'm trying to install a new CD stereo in my 1989 911.. Didn't really work out as expected..
First of all, I managed to blow some fuse in the process, so now there's no ligt in the coupe..(I guess I'm just supposed to exchange a fuse..?)
Anyhow, I have managed to puzzle together the speaker wires w/o any problems, however, the power etc. is a little more tricky..
Here's what I have on the new stereo:
GND (BLACK)
PHONE (ORANGE)
DIMMER (PINK)
TO IGNITION (RED)
TO BATTERY+ (YELLOW)
PWR ANT (BLUE)
REMOTE ON (BLUE with white stripes)
What goes where?
I used to have an old blaupunkt installed..
Thanks a lot !!!
Old 11-07-2005, 04:02 PM
Monkey Wrench
Spede's Avatar
I hope you disconnected the battery as you're doing this.
Old 11-07-2005, 04:06 PM
no....
I suppose I should?
Old 11-07-2005, 04:17 PM
ruf-porsche's Avatar
Do you still have the original wiring harness? Crutchfield at one time had an adapter that plugs into the original wiring harness.
Old 11-07-2005, 04:22 PM
I'm afraid not, I have cut them all loose..
As long as I know what wire goes where I'm good to go..
Thanks!
Old 11-07-2005, 04:27 PM
Seems like you already have the answers? Maybe I don't understand the question?
red = constant power
Yellow = keyed switch (ignition)
black = ground
the rest you only use if you need them. When I did mine, also Blau, I just wired them up to the old connections after I cut off the old stereo. Worked like a charm.
FOR SURE disconnect the battery!!!
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 11-07-2005, 04:43 PM
well.. those are the connections that I have on the new stereo (not blaupunkt).
I still don't know to which wires I should connect them since I have a few different wires in the car that doesn't have the same colors (can't remember what colors they are now..). .
One wire are brown...I think..
Thanks!
Old 11-07-2005, 04:51 PM
Brown wire is normally ground on a P-Car.
Old 11-07-2005, 05:44 PM
if i were YOU........
id take it to a stereo shop
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 11-07-2005, 06:06 PM
Great thanks,..
Then all I need to know is what color are the 12v to battery and what color are the ignition power cable on the P-car?
Thanks!
Old 11-08-2005, 02:03 AM
Wer bremst verliert
JohnJL's Avatar
Disconnect the battery and connect one end of your multitester to the battery + cable. Turn the ignition key to run and you can tell what gets batt power by checking for continuity. Switch the tester to the neg batt cable, and test your wires again for continuity. Brown is usually ground, red usually power.
You can ignore the pwr antenna wire. Same with phone. Same with Remote On, unless you are wiring an amp. In that case, wire that to your amp Remote On lead. Terminate all unused wires properly.
Then again, if you left the battery connected while cutting wires I think you might be better served taking Jason's advice.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-08-2005, 03:01 AM
Some PORSCHE either came with power antenna or amplified antenna, in either case you need to hook up the power antenna wire.
Old 11-08-2005, 08:48 AM
84porsche's Avatar
Send a message via Yahoo to 84porsche
I have the adapter from Crutchfield if you need it. I was able to install my stereo without it because I already had an aftermarket unit installed that was being replaced.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 11-08-2005, 10:38 AM
Yellowbird RS's Avatar
GND (BLACK) --------------------brown
PHONE (ORANGE)----------------
DIMMER (PINK)------------------
TO IGNITION (RED)------------- yellow ignition or you can search or an start +
TO BATTERY+ (YELLOW) + always live +
PWR ANT (BLUE)
REMOTE ON (BLUE with white stripes-------AMP
X/A
Old 11-08-2005, 10:51 AM
Wer bremst verliert
JohnJL's Avatar
Hi Ruf.
I could be mistaken, but I thought the pwr antenna wire on the Blaupunkts is intended to drive an extending/collapsing antenna, not the signal amplification. Could be wrong tho. I did not connect it on my 993 install of an Alaska and I got signal fine.
john
Old 11-11-2005, 01:35 PM
Hi Ruf.
john
The antenna can drive either one. Sometime people use that wire to power up an external amp.
Old 11-11-2005, 01:49 PM
Venetian's Avatar
I had the shop where I bought my Blaupunkt CD player install it. They did an excellent job in about 1 hour. The extra charge was only about $25.
1987 Carrera, Venetian Blue.
Old 11-11-2005, 03:54 PM
