-   -   2 days of filling, priming, and blocking. (http://forums.pelicanparts.com/porsche-911-technical-forum/250417-2-days-filling-priming-blocking.html)
racemor 11-10-2005 10:21 AM
Originally posted by Halm
Use Tom's car as a benchmark and you won't go wrong.
Some inspiration?
http://forums.pelicanparts.com/uploa...1131646851.jpg
http://forums.pelicanparts.com/uploa...1131646880.jpg
ken_xman 11-10-2005 10:25 AM
Originally posted by jm529
600 is definetly necessary because he is shooting a silver met. if it was a solid color he can spray over 400.
i've been restoring cars for over 20yrs and owned a restoration shop for 15yrs. i've never seen it necessary to step up on sand paper before you paint. you block your 2k nice and straight with 220, reprime with 2k, wetsand with 400 or 600 (depending on color) and spray away.
YUP.... missed the silver metalic part, 600 is the final necessary step.
austin552 11-10-2005 11:35 AM
John are you singing German folk songs and drinking beer while sanding? If not the paint will not come out like a factory finish. http://www.pelicanparts.com/support/smileys/wat6.gif
DW SD 11-10-2005 01:09 PM
It is going to be beautiful! Good luck!
Sounds like you've got some great advice! Look forward to seeing the finished product!
Doug
jhelgesen 11-10-2005 01:44 PM
Thanks for all the advice guys. I'm taking a few days off, then I'll be back at it.....
MikeDL 11-10-2005 03:13 PM
Nice work - I did this once many years ago and I know how hard it is. A question on the wetsanding, though...I thought you shouldn't wetsand primer because it can absorb water and eventually cause the paint to fail. Are some modern primers OK for wetsanding?
atlporsche 11-11-2005 05:30 AM
some are...a modern urethane primer/sealer will resist water. any of the yellow two part high builds do this. it's a great yellow too...I almost left the car that color. kinda buttercreamy.
sjd
