Lee Lee is offline
strange smoke, followed by alternator light
Yesterday, I used a Gunson Gastester on my car, a '78 SC 3.0. I'm certain it was connected properly. Last night, after a short drive, I noticed smoke coming up through the engline lid grill. I raised the lid, but couldn't tell where it was coming from. It smelled of plastic, I think.
Today, on the way to a funeral no less, the alternator light came on. I had no choice but to drive 45 miles with it on. Once home, the battery was pretty well discharged.
I've done a lot of mechanical work on this car, but very little in the way of electrical, and I can't get to the alternator until Monday. My questions are obviously:
What would cause wires to melt, smoke, stink?
Just coincidence that the gastester was hooked up earlier?
What should I be looking for?
Daniel Crockett
'78 SC Targa
Old 11-09-2005, 06:58 PM
Will program for food
ghnat's Avatar
Maybe the alternator just died. If you lost your battery (little to no charge) then it sounds like the alternator was not charging. Check to see if the alternator turns freely. If so then you may need to rebuild it. I had one seaze up on me - broke the belt.
Does this help? If not I hope others will chime in.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 11-09-2005, 08:05 PM
Lorenfb's Avatar
The most likely possibilities:
1. a bad battery causing an excessive load on the alternator
2. an overcharging alternator (if internal regulator type probability of this increases)
3. a short to ground in the wiring (or bad harness)
4. an electrical accessory drawing excessive currents
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 11-09-2005, 08:08 PM
HarryD's Avatar
Loren.... Nope.... Too complicated.....
Us British car owners know exactly what happenend. He merely needs some of this:
and the installation kit:
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-11-2005, 12:34 AM
304065's Avatar
"Installation is the reverse of removal"
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-11-2005, 07:06 AM
Somatic Negative Optimist
Gunter's Avatar
Lee: I hope you stopped instantly when the light came on to see if the belt broke, meaning: No Cooling.
Do a search here on how to check your alternator function; lots of info.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-11-2005, 08:59 AM
HarryD's Avatar
.... except you swear in different places......
Harry
2020 MB E350 4Matic
Old 11-11-2005, 09:15 AM
