Indebted user
Sam 69 Gulf's Avatar
Carrera Brakes pin clips - needed?
Just changed the pads on my 84 and found there were no retention clips on the rear pins.
Is this a safety issue as the pins go in and out more and get looser?
Do I need to buy some and fit them?
Thanks yet again!
Sam
"Trying to drive a 911 fast is like trying to throw a hammer backwards...." Unknown source
69 w/71 2.2L and Pretty Gulf paint!
Past P Cars - 90 C4, 84 Carrera, 74 Coupe
2007 Toyota Tacoma 4dr TRD & 2005 BMW 1200GS
Old 11-11-2005, 03:25 PM
Don't know FOR SURE, but if it were me, I'd get them.
The pins on mine had to be driven out with a punch, but still.......
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 11-11-2005, 03:27 PM
you see Arthur...
jasonlee's Avatar
To be on the safe side, I would install the retainer clips. For $13.00 from our host you can get the whole kit including new pins and retainer clips for the rear. I have been advise to replace the rention clips and pins everytime I replace my pads. Hope this helps.
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 11-11-2005, 04:36 PM
Indebted user
Pins and clips
Thanks - I'll order them tomorrow
Sam
Old 11-11-2005, 05:11 PM
KobaltBlau's Avatar
If these are like the SC pins and clips, it's not just being on the safe side, it's REQUIRED. The rear pins don't have a spring collar to pound in and hold, so they are not safe without clips like the fronts are. I bet the carreras are just like the SCs.
Andy
Old 11-11-2005, 11:46 PM
KTL KTL is online now
Schleprock
KTL's Avatar
The Carrera "wide M" rear calipers do not use pins with retainer clips. The pins only have the spring collars as Andy mentioned.
Porsche stopped using the pins with clips after the 83 SC. All 84-89 Carrera calipers have pins with spring collars.
I imagine the switch was made to eliminate the potential of losing the clips? I actually like the clip method better. Easier to replace a lost clip by going to the local hardware store for one, than it is to replace a pin with a broken spring collar or one that stops "springing"
Here some pics
Spring collar
No pin hole
Kevin L
'86 Carrera "Larry"
Old 11-12-2005, 07:13 AM
KobaltBlau's Avatar
Nice post Kevin, I was not aware of that change.
Andy
Old 11-12-2005, 11:16 AM
Indebted user
I saw the coller but was not sure if a circlip fit down between the expansion ring and shoulder.
Great Help
Sam
Old 11-12-2005, 05:06 PM
