dmcproud's Avatar
lifting the 911 SC
I have a Rotary assymetrical arm lift which I like a lot.
However, I have not found a spot to lift the front or the rear of the car. I must be missing something. I have the rubber pads and the extension lift points but I can't see lifting the car by the belly pan
What am I missing and what are you guys doing to get it off the ground for service etc????
thanks
1979 911 SC Targa
1965 427 Cobra replica
Old 11-14-2005, 08:20 AM
cantdrv55's Avatar
What's a rotary assymetrical lift? Sounds expensive. All I have are two jacks. The small one I use for the front, in between the two torsion bar covers with a 2X4 as a jack pad. The big jack I use for the back on the sump plate with an old yellow pages for a jack pad.
Old 11-14-2005, 08:31 AM
dmcproud's Avatar
My Rotary Lift is like those you would see in most service bays
http://www.rotarylift.com/Products/Product_Detail/Product_Detail.asp?PN=Two-Post&CAT=Professional%20Automotive%20Service
It doesn't seem to work on my 911 though..
1979 911 SC Targa
Old 11-14-2005, 10:11 AM
safe's Avatar
In the front lift right behind the wheel in the corner of the "floor" outside the seam.
In the back you can lft at a simular spot right in fron of the wheel.
Magnus
Old 11-14-2005, 10:29 AM
cantdrv55's Avatar
There are a few guys on this board who own a scissors lift and maybe even a couple with a lift like yours. Maybe they'll chime in and post pics of their lift points. You may want to do a search again for "lifts".
Old 11-14-2005, 10:30 AM
