Harbor freight jack on sale
Hey, I just reserved one of these:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=47246
WHich seems to be the same as the more spendy one:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40105
I spoke to HF, and the person on the phone couldn't think of a way they're different, except you don't get fancy blue. It's still $169 in the store, but if you print out the web page they give it to you for that price. I figure for $50 I can go without blue.
Just thought I'd pass it along.
Edited to actually show the expensive jack I meant to in the beginning.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 11-17-2005, 09:06 AM
Just keep in mind that this jack lifts only to 17-1/2" high,and costs $130.
Sears has a 3 ton jack, non-aluminum, that lifts to 20" high and costs only $90. Those 3-1/2" makes all the difference when you want to drop your engine or get enough room under your car to crawl under there to do some work.
Granted, Sears' weighs more, but then how many of us need to be lugging our jacks from one side of NASCAR to the other side during a race? If we did, the Team would pay for our jacks, and you couldn't take it home.
Could this be a case of needing bragging rights?
Andras
1983 911SC The Chocolate Kiss
1998 Audi A6 Quattro (Family Car)
2002 Audi TT Roadster (Wifey's Car)
1992 Mazda Miata (Daughter's Car)
1991 Honda VFR750F Interceptor
1982 Honda VF750S Sabre
Old 11-17-2005, 09:23 AM
Early_S_Man's Avatar
Porsche Crest
Those aren't the same jack ...
17.5" lift height at the saddle vs 14. 5"
35 lbs vs 24 lbs
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-17-2005, 09:24 AM
Warren - good call. The cheap one lifts even higher than the expensive one.
Andras - I looked at the sears one, and it has a minimum height of 5 3/4", vs. 3.5" for the HF model. Could be an issue on lower cars. I'm thinking I can get a couple of 2x10s and lift the car the extra couple of inches once it's already on the jackstands.
Do the AC models that Pelican sells ever go on sale? I bought a sears jack a while back, returned it b/c it's made in china, and now I'm going with this one, made in Taiwan. I trust Taiwanese quality over chinese, but I'd still rather buy american. Just can't seem to find reasonably priced american machinery anymore. Anyone know a source?
89 Carrera 3.4
Old 11-17-2005, 09:59 AM
I've found that I can always just lift the car with one hand while pushing in the jack with the other (and this with a hockey puck on the saddle cup to keep from marring anything). The hockey puck also helps when you're lifting from below the engine, on the metal lug, and want the rear of the car raised more than 17". With it lifted from the back, both rear wheels are off the ground for tire removal, for CV joint work, etc. etc.
Then, if I want the sides lifted, the trusty jack plate is high enough that 5" minimum height is no problem. And again, the 20" lift is great for tire switching front to rear, or track to street tires.
Andras
Old 11-17-2005, 10:09 AM
Czar of C.R.A.P.
dfink's Avatar
Sam's club has a large shop style jack with I think 21" or 23" lift for $79.95
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 11-17-2005, 11:27 AM
ruf-porsche's Avatar
Ever try WAL-MART ?
Old 11-17-2005, 12:57 PM
I think it's the other way around....
Warren & Ron, may you rest in Peace.
Old 11-17-2005, 12:59 PM
I bought that Harbor Frieght jack (47246) about a year ago. There was a special in the store and it cost me about 90 bucks. I have a steel Sears jack, but this Harbor Freight one is much lighter and gets the wheels up in three pumps. That commercial size steel jack at Sams Club looked pretty good, but it was so heavy that I would have needed some sort of jack to get it into the car to get it home.
'82 911 SC
Old 11-17-2005, 01:28 PM
I think I've seen the Sam's club jack dfink is talking about and it is aluminum. Anyone have one? I asked the wifey for one for Christmas.
Old 11-17-2005, 01:33 PM
randywebb's Avatar
Wal-Mart??
They sell almost exclusively Chinese, not American, machinery.
Look carefully thru the American flags and you might find something from a Chinese place with an American PO Box for a "head office"...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-17-2005, 01:47 PM
Imcoz's Avatar
This one's definitely cooler... and it's Jeg's, and on sale.
http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?catalogId=10002&storeId=10001&categoryId=22795&parentCategoryId=10785&langId=-1
Coz
88 911
72 914-6 Vintage Racer
76 914-6 Vintage Racer
Old 11-17-2005, 01:50 PM
The Jeg's jack is rated at 1.5 tons. That's 2500 lb.; close to the weight of most 911s. Granted, folks usually lift only one end and rarely if all, lift the entire vehicle. And it being aluminum, there's usually not a lot of margin in structural strength compared with good ole' heavy pig iron.
Good timing. I'm currently looking around for something that's decent in the 3 ton capacity range.
Sherwood
Old 11-17-2005, 02:05 PM
Bill Verburg's Avatar
I've never lifted the whole car w/ a floor jack.
there are several different Harbor Freight aluminum jacks so shop carefully for the one that suits your use. I've had mine for 3-4 yrs now and it works fine lifting up a whole side of even a porker like my S4V8.
I have 4 different floor jacks, 3 steel and the HF al. I always grab the HF
Bill Verburg
Old 11-17-2005, 02:14 PM
Dfink - Checked Sam's club after reading your post - found one that matches your desc - chinese made.
Rick - Pretty sure on this one - silver = cheap = 17.5 inches, blue = expensive = 14.75 inches.
Wal Mart - I have issues with them anyway, would rather buy from a manufacturer. And much of their stuff is chinese, as Randy mentioned.
Bill - which HF jack do you use?
89 Carrera 3.4
Old 11-17-2005, 02:41 PM
Ok, I see the confusion - I posted the wrong dang link to the expensive one.
Apparently attention to detail is not a strong point. Here's the identical $50-blue paint version:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40105
89 Carrera 3.4
Old 11-17-2005, 02:43 PM
Dunno
it says
long frame 3000 lb
Bill Verburg
Old 11-17-2005, 02:46 PM
poorsha's Avatar
I sprang for the AC jack before our host had them available.
Best darn jack I've ever used (but not cheap)
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 11-17-2005, 03:01 PM
randywebb's Avatar
I have a Norco (nice steel jack) and the Sears Al one. I also always grab the Al one ... it's just easier to use...
Old 11-17-2005, 03:21 PM
autobonrun's Avatar
Same here, I had two jacks fail within a three year period. Slow leaks. I sprang for the AC Hydraulic as well; the high lift model. 29 inch lift height and 2900 lb capacity. Not only are they not cheap, they are not light either (over 80 lbs) but excellent quality and a 5 year warranty. But being only 3" at the front, it slides all the way under my lowered SC.
Old 11-17-2005, 03:44 PM
