harness sub belt-how to add?
I have recently installed a used set of Corbeau CR1 seats. These have the cutouts on the backrest for harness's to come thru but does not have a slot in the seat for a anti-sub belt. So other than cutting a slot in the seat is there a alternate way of mounting the sub belt? I want to use harnesses for autocross and DE's and am under the impression that I have to have a 5 point for DE's. Or can you get away with 4 point? Help me out here guys
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Garage dweller
Sub-belt - I made my own sub slots
There's a lot of debate on this list regarding belts. The DE's that I've run do not require harnesses, however after doing a lot of research I felt better getting the best harnesses I could (IMO). I got a set of 6 point Shroth and am very happy.
My car was equipped with an older set of cloth Recaros that did not have a sub-belt slot. I put slots in myself. I was a little worried in that I'm generally very particular about any mods to the car being functional but also maintaining very high aesthetics. I cut an 8" slot in the cloth cover and completely through the foam cushion. I then hand stitched in a cloth "tube" to provide a liner through the cushion. I doubt too many would ever notice that the seats did come that way.
Don Sjolin IIIEURO AUTOWERKS 616.874.7932 |
Southern Class & Sass
Either run a single sub through the seat bottom, or run dual subs over the seat sides and sit on them. Do not run the sub over the seat front.
Personally, I'd go with the dual sub six-point set up.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Bandwidth AbUser
x2
Jim R. |
x3
Use 6 point sub, attached back where the lap belts are attached & sit on them. Len |
