goldgunner's Avatar
Tunnel - Firewall Holes
Any one have a photo or drawing reference of all of the Tunnel - Firewall holes labeled for use - purpose?
Some good info here on the conduits, but not the other holes:
OOOOOPS, What's in the tunnel?
I've searched about every combo of description query...no joy.
Thanks!
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 11-13-2005, 10:06 AM
goldgunner's Avatar
Please try this one:
What is the large oval / ovoid hole in the engine firewall / bulkhead used for?
Old 11-13-2005, 12:53 PM
What is the year of your car and do you have a pic to show what you are looking for?
83 SC
Old 11-13-2005, 05:07 PM
goldgunner's Avatar
Here's a pic.
Assumption is the top right hole is for the main wire harness.
What's the oval hole at bottom right?
Old 11-16-2005, 12:25 PM
Work in Progress
Rich76_911s's Avatar
Fuel Lines? I have an 80 SC and if you don't have a for sure answer I will post what is comming out of the oval on my car tonight.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 11-16-2005, 12:35 PM
goldgunner's Avatar
Fuel lines run thru the left side out their own openings...
Old 11-16-2005, 12:50 PM
GIBSON's Avatar
Electonic speedo drive, uses a large rubber cover that fits over that oval hole... if memory serves..
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 11-16-2005, 01:12 PM
I have an early car, back end is apart.. My speedo comes out of the hole you are referring to.. not sure if its the same for your year or not.. hope this helps.
david
Old 11-16-2005, 01:29 PM
Goldrunner,
That 8mm stud to the right in your photo is the transmission ground strap connection point. The flat disc-space around it should be bare metal to insure a good ground. If you don't clean it off, you will have no end of electrical problems.
Old 11-16-2005, 05:13 PM
goldgunner's Avatar
thanks Brian - with that reminder I should - I hope - remember to prep it well.
Old 11-16-2005, 05:58 PM
