Do SCs kill batteries like 964s and 993s?
Just bought my first SC. My other 911s : 964, 993 and 997 all killed my battery within 10 months so I just disconnected the battery between uses. Problem solved. I never cared for battery tenders. Do SCs also kill batteries as well? Because I’ll disconnect the battery on my SC if I need to between drives. Thanks.
Old 01-21-2021, 04:01 PM
the early SCs - at least mine - 1980 SC Euro spec - the only electrical component to operate with the key off - out - is the clock. I have no computer - components talking to each other in my absence. But if you are going to leave it dormant for 2+ months - disconnect neg term../ just my opinion
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 01-21-2021, 04:07 PM
Yes, mine is a 78 SC. It’’ll never be dormant for more than 2 weeks.
Old 01-21-2021, 04:24 PM
Reiver
Reiver's Avatar
Never had an issue...a radio that saves stations...that's it.
De Oppresso Liber
Strength and Honor 5th Legion
Old 01-21-2021, 05:19 PM
Less thaN $10
_______________________________________________
45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop.
Old 01-21-2021, 05:32 PM
Flojo's Avatar
mine is a 79, let's call it identical, no issues either.
and since I don't even have a radio my little 45Ah VARTA battery (9,8kg) does a perfect job. 2 years now.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 01-22-2021, 02:18 AM
'73 911 T Targa
What's wrong with a battery tender?
I have a Noco on mine. It keeps the batteries topped up which prolongs their life and makes it crank fast for quick starts after hibernation.
Old 01-22-2021, 04:01 AM
My '88, 3.2 batteries last between 5-6 years only.
Merv
Porsche 2003 996 Turbo
Porsche 1988 911 Carrera
Old 01-22-2021, 04:32 AM
MBAtarga's Avatar
I've owned my '83 for 20 years as of this May. I've bought 2 batteries - don't recall how long the "original" battery lasted that was with the car when I bought it.
Mark
'83 SC Targa - since 5/5/2001
Old 01-22-2021, 06:06 AM
SC Battery
I just replaced my ‘82 SC battery after 10 years (and I don’t know how old it was). I replaced my original 2005 e46 M3 battery in 2019.
I use a tender with quick connections, very easy to use, and I do believe it adds years to the battery life.
Old 01-22-2021, 08:49 AM
What the ?
glewis80SC's Avatar
1980 no issues with battery drainage.
SCWDP 73
1980 SC
Harley Davidson Road King
9/11/01 FDNY/343 Never Forget!
Old 01-22-2021, 10:49 AM
Wildman Emeritus
My clock will drain my battery to a point that the car won't start in about 4 months without a tender. It will turn over briefly but that's it until I charge the battery. QAD tender has solved that issue and made for a Spring smile when I can just get in and take that first drive with no mucking about.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 01-23-2021, 06:41 AM
Walt Fricke's Avatar
If you hook an ammeter into the system with the ignition off, you can see the clock tick - the solenoid pulling the spring tight again. Not much current, though.
Still, batteries self discharge, so a tender is a good idea, and probably better than a disconnect.
Old 01-23-2021, 04:36 PM
Porsche made battery-killing cars? Hmmm. Maybe an electrical, charging, storage or voodoo issue.
Sherwood
Old 01-23-2021, 06:10 PM
Bill Douglas's Avatar
My 1979 SC's Bosch brand battery lasted about 12 years. No battery tender/charging system, it was just there when I needed it.
I replaced it with the correct sized battery from Supercheap Auto and it died 8 months later. They got a bit snarly when I pointed out to them it had a three year guarantee and please replace it. Haha, after a few kind words on my part they replaced it.
Old 01-23-2021, 10:12 PM
