-   -   What's that noise? (http://forums.pelicanparts.com/porsche-911-technical-forum/251808-whats-noise.html)
wholberg 11-17-2005 04:07 PM
What's that noise?
As the weather has gotten cold, my 87 Carrera has started making an unusual noise on startup.
When the engine fires up, I hear a high-pitched squeal that lasts for about one-half second. It is not terribly loud, and it does not recur when the engine is warm. On this forum, I have read that tensioners going bad gives a rattling sound, but this sounds like a quiet version of a slipping power steering belt on a old Chevy. I have checked the fan belt and the tension is OK.
Any other ideas?
Thanks.
WERK I 11-17-2005 04:38 PM
Still could be the belt. If it's old, the inside of the belt(grip side) gets hard and will slip making a squealing sound, even if the tension is ok.
patkeefe 11-17-2005 04:54 PM
Start the car with the belt off tomorrow when it's cold and see if it still does it. If it does, then worry.
KFC911 11-18-2005 06:02 AM
Yep, I'd bet on the fan belt...I had my outer pulley half replated a while back, and I'm still getting a similar noise 3K miles later...mostly when cold, and both upon startup and shut down. What Pat said....
scottb 11-18-2005 10:55 AM
A way to do a quick check to see if it is the belt is to give it a shot of WD-40. If it doesn't squeal, then you know the old belt is dry and needs to be replaced. Our host sells belts. If you're buying belts, buy two -- one for installation on the car now, and the other to carry in your tool kit.
wholberg 11-18-2005 03:31 PM
I'll replace the belt this weekend as I have a good one in the toolkit. We'll see what happens then
