weber 40IDA-3C accelerator pump valve
In need of the circular pump valve disc that is located within the accelerator pump. Purchased a nice set of weber 40IDA-3C carbs at the Hershey swap meet three years ago. Decided it would be a great winter project to install them this year.
Purchased rebuild kits to go through the carbs and at the same time to see what jets were in the carbs and make the necessary changes needed. Everything was perfect and almost new until I took one of the accelerator pump apart and found the round pump valve plate that is located within the accelerator pump was missing on one of the carbs. Anyone have an extra one or know where I can purchase one. It is item number 25 on the weber carb break down picture - part number 64190.004 I also need an idle mixture screw - item 62 on the Weber carb break down picture - part number 64750.004. One has a slight bend in it and I would like to replace it. Appreciate any and all info that can be provided. Last edited by ssrodder; 11-28-2016 at 08:12 AM.. Reason: spelling |
Vintage Owner
Paul Abbot at Performance Oriented or PMO?
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Thank you for the info. I have emailed Performance Oriented.
