3.2 conversion Tach wiring
Anyone know how to wire a 1987 tach in a 1976 car. Its for 2.7 to 3.2 conversion. I put the same numbers back from the old tach to the new, but still have unused terminals.
76 911S 82 911SC Targa (Hot Rod In The Making) |
Im currently doing 3.2 into my 72, I found on the 3.2 there are two wires from the DME for the tach one is black (I think) and the other is black/purple as was the early wiring. From my research you use the black/purple from the DME to the tach gauge and just tape the other one off unused. Never managed to find the purpose of the other tach wire yet.
Anyone know? Steve |
Sorry just re read your post and notice your using the later tach, Y you change it im sure the early tach's will still work with the 3.2?
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 |
The earlier tach does work!! Thanks for the help!! I used the black/purple wire. It goes on the #2 terminal while #1 and #3 stay on their terminals. The existing #2 wire is not needed.
Thanks Again
ASE Master Tech - 35 yrs
new issue - worth knowing about
![]() apparently our older tachs can eventually "fry" the DME, even tho they seem to work ![]() 914 3.2 conversions - . wiring diagram for 3.2 tach here Tachometer tap 3.2
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
If you wire the shift light output from the DME to the tachometer input you will damage your DME. I had to repair this multiple times.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
DME is NOT REPAIRABLE ![]() whereas you were able to repair yours after the multiple goofs .
The DME is repairable no matter what broke. It all depends on having access to the right parts. What Mark E. was told by Steve W. is unfortunately mis-information. I did repair three units for Steve in the past.
There is no issue whatsoever using an early tachometer with the 3.2 DME. The ONLY issue arises when the shift light output gets hooked up by mistake to the tachometer. And I can modify any 3.2 DME to prevent this from damaging it. Ingo
