Ultimate Brake Setup
As it is getting colder here in the northeast, I have started to embark on my annual winter car projects. What would be considered to be an ideal brake setup for the track? (i.e. VCI, etc)
Mark
1987 Carrera
2018 GMC Sierra Denali 2500 Duramax
2012 Harley Davidson FLHX Street Glide
Old 11-18-2005, 02:21 PM
Bill Verburg's Avatar
Have you read this?
Other than a few recent variations on a theme it is pretty comprehensiveI Even if I do say so myself).
The sweet spot is 993 calipers on 930 or 930 sized rotors all around
Bill Verburg
Old 11-18-2005, 02:37 PM
GrantG's Avatar
I have the custom 930 Turbo setup from Steve at Rennsport and it has fantastic feel and fade-proof performance (and fits under Fuchs 15" rims)
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 11-18-2005, 02:54 PM
That's because of the rotors, there are several relatively minor technical reasons why the 993s are preferred.
Bill Verburg
Old 11-18-2005, 03:44 PM
curlesw's Avatar
Did you mean "sweet spot is 993 calipers on 933 or 930 sized rotors all around "?
Wayne C.
83 SC
Old 11-18-2005, 03:49 PM
930 sized rotors
304x32 front 309x28 rear
Bill Verburg
Old 11-18-2005, 03:52 PM
curlesw's Avatar
Ah, got it, thanks.
Wayne C.
83 SC
Old 11-18-2005, 03:53 PM
GrantG's Avatar
Bill - Will 993 calipers still fit under Fuch 15's? What are the advantages of the 993 calipers over the machined 930's? Is it the staggered piston sizes? I noticed that my 993 wears its brake pads a bit more evenly...
Old 11-18-2005, 04:28 PM
North Coast Cab's Avatar
993 calipers will not fit under 15" fuchs and will need spacers under 16's. The 993 front pad is larger than the 930, although the rears are the same size. Another option is the 964/951 caliper front and rear. They require more machining up front, but also use the 930 sized pads front and rear. IMO these are both very nice upgrades for anyone but a hardcore racer. The 993/951 calipers are alot easier to find than the 993.
John
John
1985.5 944 GTS
Old 11-18-2005, 04:31 PM
John
John
951 rear is the same as 964 rear(once the bleeds and feeds are swapped), there is no shortage of any of them.
I've done it both ways, believe me, the 993 calipers are the way to go.
Only purists, that don't need big brakes anyway need 15s
Bill Verburg
Old 11-18-2005, 04:37 PM
GrantG's Avatar
Ouch
Old 11-18-2005, 05:18 PM
MBruns for President
JeremyD's Avatar
it cost me more money not to take Bill's advice
I'm very happy with my 993 set up.
has proven fade free even with my fat a$$ cabriolet
Old 11-18-2005, 06:17 PM
JeremyD's Avatar
rear (930 stock rotors) 993 calipers with the throats opened a little...
Old 11-18-2005, 06:19 PM
Either the 930 or 993 on 930 is all the brake any of the n/a '89 and earlier cars will ever need. Wheel/tire choice is the main differentiating factor as I broke it down on the reference page, hp/weight and track will determine need. more hp or more eweight will need more brake, some tracks are harder on brakes than others
While the ultimate would be a set of ceramic PCCBs, the next step up is 993RS, but you will need wide 17s for them. With spokes designed for caliper clearance
I think that the GTP setup is less appropriate for our cars because of bias concerns
Bill Verburg
Old 11-19-2005, 04:55 AM
Crew Chief
prooutlaw's Avatar
Bill , what has to be done to put 993 Calipers on a '83 930 ?
Any advantage over stock 930 Brakes ?
Herbert B.
GruppeB #093
Carolinas Region PCA Member
National PCA Driving Instructor
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'83 930S Slantnose (13000 miles)
'86 951 Prototype Testcar built in '84 (56000 miles) Serial #00014
'86 951
'87 944
"Life is short , drive Fast"
Old 11-19-2005, 05:04 AM
You just need the adapters in front, never seen the 993 rear adapted to the 930 3.5" trailing arm, it really dosen't get you enough to make it worth while, there are only very minor technical advantages to the 993 fronts like the differential bores which help keep taper wear to a minimum
The most comon 930 upgrade is to the 993RS like on my car or the 993tt which will look exactly the same but has less rear bias, a desireable trait or the relatively tail heavy turbos
Bill Verburg
Old 11-19-2005, 05:51 AM
Jeff Alton's Avatar
Here is some Brembo GTP's on an 84. Need a 17 inch wheel. They are slightly front biased so a dual mc with bias adjustment is recommended (By me, so take that with a grain of salt )
Cheers
www.turn3autosport.com
Old 11-19-2005, 09:01 AM
