yeuporsch's Avatar
Brake master cylinder or brake booster problem?
I have a question on how to tell the difference between a brake master cylinder failing vs. the brake booster failing.
When the engine is on, the brake pedal would be mushy and starts to give. With repeated application of the brake, it would get firm again.
With the engine off, the brake pedal is firm then gives way, going down to the floor.
I think it is the brake master cylinder. Is this correct?
Thanks,
John
Old 11-21-2005, 08:18 AM
Paco Anton's Avatar
Send a message via Yahoo to Paco Anton
I vote for the master cylinder
I had these symptoms in my BMW last month and after changing the master cylinder it was completely cured. If you don't change the mater cylinder you will see how even when the engine on, it is increasingly difficult to get the pedal firm again until it gives up.
The problem is caused by loss of pressure within the master cylinder. You could change the gaskets in the cylinder or change the whole part (I did the latter)
Paco Anton
83 SC Targa (Euro)
Old 11-21-2005, 08:31 AM
I think it is the MC
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-21-2005, 08:34 AM
Early_S_Man's Avatar
Porsche Crest
MC
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-21-2005, 09:42 AM
