Efi shopping list
Hi everyone for my 2.8L in a77 911s currently with webers.I was thinking of suzuki gtx 600 throttle bodys a ford EDIS boxster fuel injectors.But what is the best Ecu? fuel rails. The reason for the change more precise spark and fuel managment .Iam running 9.5 JEs and E cams from the cam Dr.Anyone have pics? all comments appreciated.Any guess on HP gain after mapping.
Old 11-19-2005, 09:07 AM
bump
Old 11-19-2005, 11:05 AM
David's Avatar
Motec would be the best.
There's also Autronic, DTA, Haltech, Electromotive, Megasquirt and many many more. There's much research to do to see what you'd like.
My choice would be Motec or Autronic. If you want want to go low budget, Megasquirt may be a good choice.
Old 11-19-2005, 11:39 AM
BoxsterGT's Avatar
An easy way to go is with the TWM throttles mounted on your Weber manifolds. It uses the same linkage and works well.
You can use the Mega Squirt ECU set up for EDIS.
The latest MS is V 3.0, and it only needs the EDIS coil pack, not the EDIS Ign Module.
I am running MS on a 911SC with the older V 2.2 that reqs the ign module, but am planning to upgrade to the 3.0 and eliminating this module.
We installed the TWM setup on a 74 911 Carrera that was using Webers. It was a very easy conversion. You can even use the same air cleaner assys.
If I can reach the owner, I will take some pics of it and post them.
Len
Old 11-19-2005, 01:57 PM
rfuerst911sc's Avatar
Earlier this week I ordered my TWM ITB EFI setup from Motomotions. It utilizes the Megasquirt ECU and TWM throttle bodies. I am going to use Weber manifolds opened up to match my 34mm heads and 46mm throttle bodies. Once I get the EFI up and running I will be installing the EDIS ignition which I have already purchased. For aprox. $ 3300.00 I will have a ITB EFI setup that I can program and should perform great. For that price I had to find a few items used but that's O.K. I like saving money! This will be for a mostly street driven 911.
Old 11-19-2005, 02:08 PM
Mega squirt works well and is very inexpensive
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-19-2005, 02:28 PM
thanks everyone keep it comming Iam going to check TMW
Old 11-19-2005, 04:09 PM
Jeff Alton's Avatar
Give Mike at motomotions a call, they also sell the Jenvey ITB and they are a true piece of art. Only marginally more money than the TWM
Cheers
www.turn3autosport.com
Old 11-19-2005, 04:58 PM
SDS EFI
I converted my SC to EFI using system from SDSEFI. I put together some basic documentation and links at:
http://home.comcast.net/~tisserand/SDS_Install.htm
Daniel Tisserand
1981 SC 3.2L short stroke
Old 11-19-2005, 09:24 PM
Formerly bb80sc
Vipergrün's Avatar
Muahahahahha! I have he Jenvey 48mm tapered ITB's sitting on my desk right now.....no camera, though. I am doing fuel only at this point and am using the MegaSquirt purchased from Mike at MotoMotions. He is a great resource and VERY helpful. IMHO, by the time you get the GXXR's ITB's working correctly, you should go the TWM or Jenvey's and with something that we know works and looks semi-OEM. I had a couple of parts missing from the Jenvey's Porsche kit and Mack@Emerald Performance and Jenvey got right on it and made things right. All is good.....just need a car to install them on I'll post updates on my progress... FYI, the TWM3006 and the Jenvey's are true ITB's, the TWM3003's are more like webers, not that it matters.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 11-19-2005, 10:30 PM
Jeff Alton's Avatar
What size motor are you using the 48's on?
Cheers
Old 11-19-2005, 10:31 PM
Formerly bb80sc
Vipergrün's Avatar
Cheers
For now, a stock 3.0l, but will eventually get pistons and cams.....
Remember, though, I have an 80SC with 34mm intakes, so that's where the taper comes in. If I ever go larger with intake ports, I'd need to ream out the manifolds to match...
A very reputable SoCal P-car shop has indicated I could see 25-35HP just with the ITB/EFI conversion, then another similar amount after internal changes.
Cheers
-Brad
2015 Cayman GTS
Old 11-19-2005, 10:36 PM
Daniel,
Nice job with the documents for the SDS EFI
Old 11-19-2005, 10:40 PM
Wow great info guys ! post pics asap thanks
Old 11-20-2005, 07:59 AM
Mike Bonkalski's Avatar
My setup is almost identical to the one you are thinking about...
Throttle Body / EFI project
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 11-20-2005, 08:04 AM
Thanks Mike thats it ! its so exciting to get the EFI topic going agian
Old 11-20-2005, 09:27 AM
