washer bottel fitment
I have an 89 911 cab with a wide body conversion.
When I got the car I didnt know that i had so many parts missing. any way I was out for a ride this weekend and went to use the windsheild washers and found that they didnt work. ( figured I was out of fluid..... WRONG) I found that someone had removed the bottel and pump and all the hoses. I bought a new bottel and low and behold the reason it was all gone was there isnt room for it where it belongs under the left headlamp. Has anyone run into this or dose anyone know of a bottle I can put in that will fit somewhere. Thanks for the help
Shiny side up, Rubber side down, Its the fastest way around the track. |
GFCC
What is in the way. It should fit. The bottle is the same for 74-89.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
I removed my large washer bottle and re-plumbed the hoses to use only the small washer bottle under the front hood ( for concentrated cleaner/de-icer). I believe this is the same set up that the RS America cars used. If I am not mistaken, there are past threads that cover this.
Good luck, Ben |
There are 2 different bottles
'74 - '83 and '84 - '89 the late bottles have an indentation to clear the drivers side fog light, early ones do not. I posted a parts list awhile ago to update to the 964RS/993RS system which will look like this
Bill,
Could you post a link to the parts list? I've updated the front valance on my 1983 to the 84-89 style and need to update the washer bottle. Thanks, Mike mrdowns@comcast.net
Mike 1983 911 Cabriolet (3.6L conversion) Guards Red 2007 BMW X5 |
Thanks!!
