Flat or drilled?
Picked up a couple Zimmerman drilled rotors the other day for a brake project. Now I'm reading how the drilled rotors are prone to cracking and that they are noisy. Should I just leave my Carrera stock rotors on? (3 DE's a year).
Reverend Ray 84 Carrera Coupe "DAS-V2" GruppeB #2119 Volvo V70SE-Wife mobile Nissan Frontier-Home Depot mobile |
From what I have seen, the drilled rotors will crack after a while
under heavy track use. I run the Zimmerman drilled on my 89 and I don't have any noise issues and really good stopping power, no fade and great looks. |
Senior Member
Same here. No problems at all but I do not track the car.
JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Hmmm, Maybe I'll procede with the rotor swap.
Automotive Monomaniac
My drilled are cracked (track use). No big deal as the cracks are tiny hairlines... bigger, and you have to replace the rotors.
I don't know what the "actual" benefits of drilled rotors are (cooling, less gas between pad and rotor, etc...), but I hear slotted are the best of both worlds.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
The smaller rotors used oem on SC and Carrera were never meant to have holes in them. The ones that are available are a marketing gimmick only, they will crack more quickly than sole od slotted.
Any rotor can be made to crack if abused enough, and the small cracks will only get bigger. To increase longevity keep them cool.
I cracked mine the first time I abused them on the track. Now, I have 993 deflectors and no splash guards on the back of the rotor - the cracks aren't growing, and the car stops much better. Keep 'em cool.
