2.7 CIS Loping - Need Help
I'm relatively new to the scene with a silver '75 Targa with what appears to be a stock 2.7 and CIS. I've brought it back from the brink of the crusher, and just had it repainted.
I am having a problem diagnosing an issue. The car runs rough at idle which I believe to be injectors. I have started replacing them as I identify which cylinders aren't running properly at idle. It accelerates like a dream once over 3000 RPM, and decelerates without popping, missing, or backfire. At lower RPM, especially 1700 to 2500 it bucks like a horse regardless of being hot or cold, and regardless of gear or speed. I've ruled out electrical as it should break down under load vs the other way around. That leaves me at fuel, but don't understand why low RPM would cause the loping. When driving, I have to downshift or accelerate beyond this RPM band. Any thoughts appreciated.
My therapist says that if I can touch it, it's real! '75 911 Targa |
Blowmeup,
Have you checked your ignition timing? Rex
1975 911s 1997 Saab 900s |
I have not checked the timing. What is your thought; too much advanced/retarded, or lack thereof?
Thanks Bob
I 2nd the timing, either way could cause that I think.
Donnie Currently Porsche-less.....
GOT TURBO..
Timming slightly retarded, and a minor mixture adjustment( just did one last week, same issue)
What number did you find so far is running bad??? |
Check timing, clean/replace your points. Injectors could be bad- you can test these by pulling them out and watching the spray pattern. Also your WUR could be out of adjustment or malfunctioning, which affects mixture, although the mixture screw is a better place to start.
Sounds like your fuel mixture might be to lean.
A sick idle and rough run out started me down this path initially. The car sat at the body shop for close to a year and came out barely running. #5 was not running but had good spark (I changed all the plugs with no improvement) and the injector was in rough shape.
I compared it to #4 and it wasn't right. So, I changed #5 and then #4 after I saw what a new one did. It runs much more smoothly now, but still has rough idle and this loping issue. I am convinced that I will renew the other injectors as they are OK under load, but don't have the fine mist at low volume like the new ones which probably accounts for my poor idle. I'm glad that 'lean' is coming forward from your experiences as the old plugs were telling me this when I removed them i.e. white deposits. The points are also another area of suspicion. I think that I will just replace them. Since I have replaced the two injectors and earlier added Techron to the tank, it has started a new trick. It runs the best it ever has, and then dies completely. On the way to a dead stall, it backfires through the intake. Once dead, I can restart until the next time it repeats. Is this air in the fuel system, or would points do this also? Coil? Thanks Bob
Designer King
I'm thinking points, too. Also, check to see if your dizzy turns and springs back easilu (use the rotor). How does the car start/warmup from cold? Do you have a popoff valve? Check the usuals: air leaks, WUR, AAR.
Finally, see my recent thread on broken head studs. You may have a pulled one on your 2.7.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Bob,
It is best to do this one thing at a time. 1) Check your timing/ points 2) Change fuel filter (buy 2) 2) Check your cis fuel system pressures 3) Check each injector 4) Check fuel dizzy Did you drain the fuel first, or is this 1 year old gas+crud? You may be better off draining the tank, cleaning the in tank screen, replacing rear filter, then filling up with fresh gas. It sounds as though there are multiple issues, and bad gas is the easiest to fix, then points, timing. It took me about a month to get mine right, but it is RIGHT. Fires right up, no sputtering etc.
I will check the dizzy. The car used to start cold without issues, but since it started the stalling routine, it's hard to tell. It seemed to improve with time, so I'm also thinking that perhaps some debris came loose via the Techron and was plugging the fuel distributor and is now working its way out.
I was also thinking AAR, but how to access it without taking the entire fuel system off the car. It's in the back and impossible to see/access? Any tips? Thanks Bob
How about that plunger thing for the CIS air intake regulator? I've read it could stick when old and brittle.
http://members.rennlist.com/jimwms/CIS/CIShome.html
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
I didn't drain the tank as I completely drained and cleaned the tank/filter just before it went into the shop. The fuel level was very low going in (intentionally) and I have put two tanks through since getting it back.
I agree with limiting the hunt. I will complete the injector replacement (needs it anyway), points, and timing. Should be in a better position to diagnose once these are completed. Thanks for the pointers. Bob
Kach22,
I read this also, and it is not stuck. It did lead me down the mixture path, however, and also leads me to believe that it is running too lean. I think that I will do the injectors, points, and timing before I start messing with the mixture as poor fuel flow through the injectors will also have the same leaning effect. Thanks Bob
Keep us posted..
I replaced the points and rotor today, and took a ride. The stalling/backfiring was the points on the way out. The new points provide much better ignition than the old ones ever did.
I retarded the timing a little, and the loping is less of an issue, but it is definitely still there. I have a dist. cap and more injectors coming for Friday. BTW, I can't seem to get the idle to adjust higher. It wants to live around the 500 rpm level regardless of what I do. Once I get the cap and injectors in, I will let you know what's happening. Thanks Bob
What did you set the timing to? Idle issue is probably a vacuum leak. I just replaced all mine instead of messing with it. You can get the hose at any autozone, napa etc.
I didn't use the strobe light, but rather marked the position and tried going either way to check the result.
I just couldn't seem to bring myself to run it up to 6000 rpm to set the thing. Is that really what needs to be done on these things? I don't even go that high when out for a thrill.....
Bollweevil
Next time your points start to go, you might consider replacing them with the Petronix Ignitor (available from our host). I did this upgrade a couple of years ago and highly recommend it. It is easy to install and totally eliminates the hassle of dealing with points.
Jack Mansfield
Jack 74 911 Coupe 2.7L - K21 Option - S suspension |
Throttle Operated Control Regulator
OK, after considerable reading I realize that I am missing the TOCR listed on this link Item #28 on the diagram.
http://members.rennlist.com/jimwms/CIS/CIShome.html This would explain the lean operation. Can anyone advise where I can get one and/or how critical it is to 75 2.7 operation? Thanks Bob
