Bilsteins or Boges - which were stock on '88 Carreras?
So while I was under the car changing tranny fluid, I noticed that in the rear I have green Bilsteins (HD, I assume) and in the front, it has a green housing with an orange-ish Boge insert.
Anyone have any ideas as to why an '88 would be set up this way (stock ride height)? And which of the two brands was stock in '88?
Thanks,
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 11-26-2005, 10:51 AM
lally911's Avatar
Just took the struts off a friends 88 and they were Boge.
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 11-26-2005, 11:08 AM
Don Plumley's Avatar
Ah, the benefit of complete records....
How many miles on the car?
Some shops change the rears if they drop the engine - but don't replace the front (that's what the PO of mine did). Boge struts are stock for Carrera's, but of course you can put in a Bilstein insert (and should so if the front is original).
Don Plumley
M235i
Old 11-26-2005, 11:09 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Both were stock in '88. You could get Boge or Bilstein.
Kevin L
'86 Carrera "Larry"
Old 11-26-2005, 11:14 AM
KobaltBlau's Avatar
"stock" - yes, but bilsteins were optional, while boges were standard (as with many years of 911s).
Andy
Old 11-26-2005, 11:43 AM
Were the Boge strut housings green (I seem to remember them being black)? I don't know why anyone would replace Bilsteins with Boge inserts but that's how it looks to these untrained eyes.
Mark
'82 SC Targa (RIP)
Old 11-26-2005, 12:12 PM
Boge housings are usually black.... but they can be painted ( ! )
Boge outside surface should have some identification stampings on it...maybe beneath a layer of Cosmoline. Look.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-26-2005, 12:34 PM
Jeff Alton's Avatar
The Bistein will also have a roll pin at the bottom of the strut housing, just above the ball joint fastening bolt. This roll pin holds the strut cartridge in place, Boges do not have them. The boges also have boge stamped on them about half way up the body of the strut.
Cheers
www.turn3autosport.com
Old 11-26-2005, 12:51 PM
Plus the Bilsteins ( i.e strut and housing)...won't have a "bulge" on the shock body right above the welded-on locating ring that holds the spindle in-place. This lack of "bulge"...allows raising the spindles to RSR specs for Bilstein struts. Normally, this can't be done with Boges or Koni's. ( Chris Bennet... I know there are exceptions... )
- Wil
Wil Ferch
Old 11-26-2005, 12:56 PM
