-   -   Any trick to seperating hub from rotor? (http://forums.pelicanparts.com/porsche-911-technical-forum/253524-any-trick-seperating-hub-rotor.html)
IAN 11-28-2005 10:53 AM
I'm taking it all apart. The struts are off the car.
I have removed the bolts that hold the rotor to the hub but I can't get the hub to seperate from the rotor. Any tricks?
I want to avoid big hammer action- although I would rather hit the rotor as they are cheaper than hubs...
Thanks,
Ian
adomakin 11-28-2005 11:09 AM
lots of little hits with a plastic hammer, working round it as you go. and some heat perhaps..
tshih 11-28-2005 11:12 AM
I just drop the whole assembly from a height of 3 ft making sure the rotor hits the pavement first. The hub usually dislodge from the rotor when the impact shears the rusted together parts.
MotoSook 11-28-2005 11:27 AM
A steel hammer on the OD of the rotor will do it. Just tap it around and the rust will let go. The taps witht he hammer will break loose the rust scales will help your cooling too.
911SCfanatic 11-28-2005 11:28 AM
heavy cast iron hammer with rubber ends.
ruf-porsche 11-28-2005 11:29 AM
Dead blow hammer the large size, not the small size.
mackskibum 11-28-2005 11:43 AM
If you have an air hammer with a flat round attachment (not a chisel, punch or sheet metal chisel)- use on hub area working your way around while hitting with 5 second or so blasts- should eventually separate without damage to the rotor.
4to8m8 11-28-2005 11:53 AM
Just did mine the other night. Rubber mallet worked for me. I BBQ'd the hub to get the races out.
ruf-porsche 11-28-2005 12:08 PM
Hopefully you'll clean the grille before the next BBQ at your house.
