LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Registered Loser
Exclamation Check Your CV Bolts Boys!!
YIKES! I replaced my CV joints about a month ago and then yesterday my car began making that familiar "clunk clunk" sound again. I coud barely believe what I was hearing because the CV's were brand new. But then fellow Pelican Chrisbennet suggested I check to see if the CV BOLTS had backed themselves out and VOILA! Chris was correct. The bolts on the outer CV had backed themselves all the way out and one had even "gone on holiday" and was missing from the car!
So I re-torqued them all and the clunking is gone. So here is a warning to all: Check your CV bolts!!
Owner of a wrecked 944
Old 11-24-2005, 08:10 PM
Non Compos Mentis
I haven't checked mine for a while. I will soon!
Thanx for the reminder.
Old 11-24-2005, 08:33 PM
Me like track days
Craig 930 RS's Avatar
Happened here..check em!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-24-2005, 08:34 PM
walt's Avatar
Did you use schnoor washers? I used fresh bolts with these locking washers and, so far, so good.
Walt
82SC 3.0
81SC 3.6
Zeke's Avatar
CV bolts need to be retorqued after 100 miles. That is with new washers, clean thread bores and Loctite. W/o those factors done correctly, you may not get 100 miles. Seems like the 2nd torquing will keep them tight for some time, but it never hurts to check at oil change intervals.
Old 11-24-2005, 11:24 PM
emcdan's Avatar
I noticed that 3 on my driver side had backed out recently. I locited and re-torqued but they have loosened again. Does anyone else have some good solutions?
Deutsche Fahrzeuge
78' 911SC
03' 325I BMW
03' KTM 450sx
05' S2000 (daughters)
Old 11-25-2005, 12:24 PM
saftey wire may be unnecessary for most guys.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-25-2005, 12:40 PM
randywebb's Avatar
Soln is to use new Schnorr washers, and to clean the bolt threads and female threads with brake cleaner - should be no grease in there. Go back and retorque after 100 miles as per above.
Some use Loctite - I don't and never have problems.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-25-2005, 01:49 PM
GIBSON's Avatar
Randy's technique has worked well for me. In the 70's I was driving on the 10 freeway at the 405 interchange when one of the CV joints parted company with the trans. That is not a great place to loose drive. No breakdown lane. Since then I've checked them every few months.
It's really easy for the CV bolt to be covered in grease on the early non-sealed CV joints and back right out. Clean bolts, new washers and check torque at 100 miles.
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 11-25-2005, 02:26 PM
Bill is Dead.
cashflyer's Avatar
Originally posted by RoninLB
saftey wire ...
That's EXACTLY what I was going to suggest!
Old 11-25-2005, 02:29 PM
safe's Avatar
What is a Schnorr?
Picture?
Magnus
Old 11-25-2005, 02:38 PM
Information Junky
island911's Avatar
saftey wire ... schnoor washers . .. loctite . ..
you guys . . NONE of that is enough.
Every CV bolt should have a calibrated torque wrench engaged always. -- and never drive a car with CV's!
seriously...
My thoughts exactly. (except for new washers)
Dry bolt-head & contact surfaces will provide plenty of torque lock to keep the bolt in place. (edit: assuming/implied proper torque)
Old 11-25-2005, 02:50 PM
randywebb's Avatar
Magnus - you need to do some searches - try to put recale in the search box - he did a nice how to do it on this
those are special serrated lock washers
also get a Bentley manual and find the VW manual pages someone posted when you search
you will then be well prepared to do it right.
Old 11-25-2005, 03:28 PM
efhughes3's Avatar
Very timely post, as I'll be bolting my outers up tomorrow as part of the re-assembly of my rear suspension. Thanks!
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 11-25-2005, 03:58 PM
Semper drive!
rcecale's Avatar
Lots of great info on this topic from the likes of Randy Webb and Grady Clay here
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 11-25-2005, 04:49 PM
Janus,
The 964 CV joints are torqued to 31 ft.lbs if you have the M8 panhead screws and 59 ft.lbs if they are M10. Also, the torque specification is WET (just the threads) not dry and the recommended lube is Optimoly HT (copper grease). The flange covers that tie two bolts together should be dry.
Old 11-25-2005, 11:15 PM
I check mine every other weekend or so since mine backed out one day. It takes all of 3 minutes with an allen key. Don't even have to take the wheel off. My drivers side bolts tend to loosen up occasionally.
14 Cayenne Turbo S
06 Cayman S
87 911 becoming 73 RSR Mary Stuart
68 TVR Tuscan LWB
66 TVR Griffith Series 400
Old 11-27-2005, 12:17 AM
safe's Avatar
If they loosen up something must be fundamentally wrong, right?
I mean they are supposed to be installed and forgotten for 100000 miles, as on all other cars.
Magnus
Old 11-27-2005, 05:24 AM
efhughes3's Avatar
Now I'm thinking about this. The factory torque specs are only about 30lft-lbs according to Bentley (8mm bolts). If this is such a common issue, doesn't that seem a little low?
Ed Hughes
2015 981 Cayman GTS
Old 11-27-2005, 05:50 AM
Somatic Negative Optimist
Gunter's Avatar
No need to apply the Grand-Unification-Theory here.
With gaskets, the bolts may have a tendency to back out because the gaskets get squished over time.
I don't use gaskets. If the mating surfaces between CV-joint, and flange are clean and true, gaskets are not necessary IMHO.
New Schnorr washers, lube the threads, BUT NO LUBE ON THE HEADS/WASHERS for wet-torque of 30 ft-lb on the 8 mm bolts.
The Allen bolts are high tensil-strength (12.9) and can take a little more.
If no halfmoon-shaped plates are used, check the bolt-length; sometimes the bolts may stick out a little and need to be ground off one or two threads.
Replace the bolts if they are really old with new ones. When the inner hex is nearly rounded off, it's time to get new ones.
Seems to work.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-27-2005, 06:40 AM
