-   -   Lifting Points (http://forums.pelicanparts.com/porsche-911-technical-forum/253672-lifting-points.html)
wcc 10-16-2006 08:25 AM
That's all I could come up with this early Monday morning. :rolleyes:
naparsei 01-28-2008 07:49 PM
Originally Posted by turborat (Post 2263740)
Weltmiester makes a jack pad to address the issues being discussed here. It is about $80.
http://forums.pelicanparts.com/uploa...1133299321.jpg
I tried to find this on the Weltmeister site, with no luck. Does anyone know if it is a Weltmeister piece, or made by someone else? Thanks, Alex
Trog 01-28-2008 08:22 PM
Courtesy of our host:
PEL-PP915232
naparsei 01-29-2008 05:03 AM
PEL-PP915232
Thanks. I thought about looking, but when I didn't see it on the Weltmeister site, I figured they didn't make it anymore. I do research for a living, you'd think I would have taken the next step. Thanks for the tip.
TheSt|G 06-19-2014 04:46 PM
Bumping an ancient thread here:
Attempting to use a lift and I can't see to get the rear arms back far enough to prevent the engine from appearing to teeter off the lift. Using the corners of the tub as recomended in the picture earlier in this thread.
Those with lift expierence, thoughts?
Gemballa2006 06-19-2014 04:58 PM
Is it safe to jack up by the rear trailing arms and then lowering onto jack stands under torsion tubes? This essentially compresses shock then lifts the rear
Flieger 06-19-2014 06:28 PM
I jacked up by the sump plate and put the jack stands inside the longitudinals on the torsion tube, then left the jack in place.
https://farm4.staticflickr.com/3845/...6e295a68_c.jpgChangingRearSprings+Heights+Balance2014June_ 002 by Max_911S_fahrer, on Flickr
TheSt|G 06-19-2014 06:39 PM
I was referring to using a lift, but I got it. Annoying that there aren't proper pads.
911_Dude 06-20-2014 04:57 AM
I have a lift and a '75 911. I use the furthest forward and rearward seam that runs along the side of the rockers and curves in at the wheel wells. On the older cars it looks like a 1/2" vertical ridge. Its very strong.
Bill Verburg 06-20-2014 06:08 AM
If lifting on a seam use a pinch weld block like this
http://forums.pelicanparts.com/uploa...1403269618.jpg
When lifting on a flat use a pad or block to distribute the load over a wider area
http://forums.pelicanparts.com/uploa...1403269684.jpg
deputydog95 09-20-2016 08:42 PM
If I need to remove my right front wheelsand don't have a jack pad that fits into the side of the car, what is the best spot to jack from to quickly do a single wheel swap?
Sent from my SM-N920V using Tapatalk
RAW911 09-21-2016 08:48 AM
From 84 Carrera Owner's Manual:
http://forums.pelicanparts.com/uploa...1474472869.jpg
deputydog95 09-21-2016 07:16 PM
Originally Posted by RAW911 (Post 9289706)
Thank you sir.
Dmitry at Pelican Parts 10-13-2016 03:40 PM
If anyone is looking for excellent, reliable jack stands check out our promo on the ESCO jack stands; 10% until the end of the month!
ESCO Jack Stands Special Offer - Pelican Parts
-Dmitry
