What are these worth?
I know they are early style heat exchangers but any idea of what years they will fit and what they are worth? I was thinking of using them on a 76 3.0 coversion but not sure they would be as good as SSI's.
87 G-50 Coupe
2001 540 sport Wagon(Wife's)
1996 Volvo 855R (work Machine)
"If it seems simple enough its probably complicated"
Old 11-29-2005, 10:57 PM
Senior Member
Hmmm, not sure exactly what in the world those are??!! They are not stock early style HE's unless someone has cut off part of the heater shrouding and modified them.
Just stole this photo from a post from Speeder (Denis) and it shows a pair of SSI's, and they had more or less the same heat ducting as the early style of HE's. You can see that there is a lot of the actual duct missing.
Also, the ducts were the air from the engine go in are very interesting. Do you have any close up photos of this area?
Your HE's would be a lot easier to install without the full length ducts, but also would not produce anywhere near as much heat.
Joe A
Old 11-30-2005, 02:06 AM
al lkosmal's Avatar
Could those be 914-6 heat exchangers?
RGruppe #669
http://www.x-faktory.com/
Old 11-30-2005, 06:15 AM
Shaun @ Tru6's Avatar
Do they look fabbed up/modified from stock?
Here's a pic of 914-6 exchangers.
Tru6 Restoration & Design
Old 11-30-2005, 06:24 AM
Friend of Warren
My guess is the bottoms of the metal shrouds rusted so someone cut them back to good metal and then welded on openings for the heater hoses. Not going to get much heat out of those.
Kurt V
Old 11-30-2005, 06:27 AM
Shaun are those yours? anyhow Looked chopped up to me
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-30-2005, 06:33 AM
hi Ben, no not mine, I pulled these off the 914 classifieds board researching the exchangers above.
Old 11-30-2005, 06:57 AM
Oh well if they were yours I would have offered a 100 dollars for them
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-30-2005, 12:06 PM
looks like early Triad Industries aftermarket units.
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 11-30-2005, 12:12 PM
And they would be yours.
Old 11-30-2005, 12:18 PM
So, are these worth putting on my 78 3.0 SC motor that is going in my 76 or would I be better just getting some SSI's? If not worth putting on my 3.0 are there other applications that would work well for some one else?
87 G-50 Coupe
Old 11-30-2005, 12:19 PM
