Where's the engine ground strap?
Possible engine drop coming up, so I've been going thru my Haynes manual to read up on the "correct" way to do it & chasing down on the hoses, electrical wires, etc. But can't find the ground strap from the engine case to the body. Isn't it supposed to be on the bottom of the case? Also, isn't there one from the tranny to the body?
73 914-6, Vintage Spyder,05 997(sold),
04 Anniversary 911 #151(sold)
08 Beck Speedster #317 (sold)
76 911S (sold) 76 911 Targa (cut up & sold)
86 951 (sold)914-6 (sold)
Old 11-29-2005, 01:33 PM
Tranny to body just above the tranny support on the left side you will see it.
Old 11-29-2005, 01:49 PM
In my '86 Targa, the ground strap is on the end of the transmission near the shift coupler.
1986 Carrera Targa - sold
1987 Carrera Coupe - sold
2003 Twin Turbo - sold
964 Coupe - on the hunt
Old 11-29-2005, 01:52 PM
So there's only the one from the tranny. Nothing on the engine?
Old 11-29-2005, 02:16 PM
len911's Avatar
Correct, only one ground strap from trans to body. See included picture. There is also a ground strap from the alternator to one of the studs on top of the case. You can only get to that one when you remove the air cover. Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 11-29-2005, 04:41 PM
There is a bunch of ground wires connected at the elbow of the blower tube, on the left side of the engine as you stare at it.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-29-2005, 07:20 PM
Add another if the lack of one is bothersome. Can't hurt. Can help the electrons find an alternate/easier path back to the battery.
Sherwood
Old 11-29-2005, 11:09 PM
blau911's Avatar
Is it easy to replace the ground strap without having to drop the tranny?
My oil temp gauge has been bouncy, despite having been inspected and tested by VDO last year who confirmed it was in good working order. I have read elsewhere that the bouncyness could be due to a bad tranny ground. I have looked at mine and it looks kind of beat up. Anyone else have this problem and replaced their ground strap?
Old 11-30-2005, 12:28 AM
rob justice's Avatar
Its no problem at all, earth stud on the body and gearbox casing are both easy to get to, gearbox one slightly more difficult. Most fiddly part is feeding the new earth cable over the top of the transmission mount but even that is hardly nothing.
Old 11-30-2005, 12:50 AM
randywebb's Avatar
Yes, easy:
1. clean up any corrosion and make everything shiny with fine emery paper - that's the mount and the strap or get new strap
2. use dielectric grease (very thin thin thin layer)
3. use new washer/nut or clean them up a bit too
Bes ure to do the body and the tranny sides of the strap & mounting surfaces
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-30-2005, 01:18 PM
