-   -   Compression testers? (http://forums.pelicanparts.com/porsche-911-technical-forum/254372-compression-testers.html)
WydRyd 12-02-2005 06:52 PM
In the process of troubleshooting my low idle/stalling condition, I decided to do a compression test on the engine to verify the internals are OK.
Is there a special, solid extension I need for these engines? The hose on the tester I bought is slightly bent, so I'm having difficulty actually getting it in at the right angle to screw into the plug hole :mad:
Very frustrating indeed :(
How do u guys do it? Is there a special "PORSCHE" tool :confused:
al lkosmal 12-02-2005 07:09 PM
I bought a compression tester from Sears, for $25 or so, that has a 12" long flexible hose. Works great.
Jeff Alton 12-02-2005 07:13 PM
The flexible hose just takes a little patience, but it is the right thing to use..
Cheers
2.7RACER 12-02-2005 07:27 PM
This is what I did to my comp gauge hose to help fit into the sparkplug hole. http://forums.pelicanparts.com/uploa...1133580445.jpg
WydRyd 12-02-2005 10:42 PM
Finally got the hose into # 6 cylinder after much friggin around. I just hope it's not going to be so bad for the rest of them. I like what you've done above Doug. Very ingenious ;)
Questions:
- Do I NEED to disable my fuel pumps?
- Must compression tests be done on a warm engine?
- How do I do a leakdown test? What type of tool/instrument is required for that?
Excuse the first-time newbie questions :)
