it was going so smooth!
Hi Guys,my first real attempt at trying to be a wrench,I am taking the strut assemblies,hub ,rotors and calipers of a parts car,the first one came off no problem,just a little time to figure things out and then on to the left side there were no problems at all until the bottom pin,the nut came off no problem but in trying to tap it out I bent it and it will not budge now.the pin is for sure pooched but how do I get it out without causing any more damage?please help,Marty
Old 12-02-2005, 05:31 PM
Marty, put the nut back on the threaded end of the pin and use a BFH to pound it loose. Then use a punch (carefully) if necessary to press it the rest of the way out. I had to do this with two of them in the past. Good luck!
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 12-02-2005, 05:40 PM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
i also used a torch to heat the surrounding metal of the strut (not the pin) to give it some room to breath.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 12-02-2005, 06:30 PM
Early_S_Man's Avatar
Porsche Crest
If you are talking about the wedge pin ... as Michael said, put a pair of sacrificial M8 nuts back on the thread and try to bend the threaded shank back straight. Then use a large C-clamp to press out the pin ... with a socket or large nut over the large end of the wedge pin so it can move out freely.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-02-2005, 09:54 PM
I just did this today. I used a BFH! and still didnt get it out. So I used the torch and heated the arm and with a bearing puller....I got it after I hit it again with a BIG F* HAMMER!....
I also love how Wayne says in his book "Then simply unscrew the tie rod from the steering rack" ......
ITS NOT EASY....AND DEFINITALY NOT SIMPLE
I guess tomorrow I will do the other one.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 12-03-2005, 07:34 PM
I guess I am glad to see I'm not the only one ,thanks for the advice guys,still haven't got the darn thing off,Marty
Old 12-04-2005, 02:50 PM
Martin
Finished my second one today. Believe it or not I found the most useful tool in this whole process was a plummers wrench. The 8 to 10 model.
I could not get turns on the tie rod with my Ford wrench or other tools, but he plummers wrench with its teeth allowed me to grip the rod and turn it and get it tight. You can also use it on taking the old tie rod loose.
Those gripping teeth are great.
Thank God I dont have to do that job any more.
Chris
Old 12-04-2005, 06:29 PM
Zeke's Avatar
It's plumber's.
Old 12-04-2005, 06:47 PM
Its a plummers
Its more than a plummers wrench!
Old 12-04-2005, 08:47 PM
the one I am having problems with is not at the tie rod bot at the bottom of the strut,Marty
Old 12-04-2005, 09:55 PM
I know just giving you heads up on the other end.
For the end you are trying to get done...
Bearing puller
BF Hammer
Torch
Good luck
Old 12-05-2005, 06:23 AM
