Need Strut info for Sport Struts
I have a 74 911 with the Koni sport struts. I dont know how to adjust them and I cant find anything in writing to explain how to do it. There is no knob at the top like the other KONI shocks.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 12-03-2005, 09:45 PM
The old koni,s were adjusted by unhooking the top and bottoming the rod in the housing and then turning . It is best done before an installation as it is quite awkward when installed. The rears are a little simpler to get at but still awkward.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 12-04-2005, 06:14 AM
randywebb's Avatar
a visual for you - there are some side projecting tabs or dogs on the bottom -- you need to turn it until they line up with some recesses and then push harder to seat them down in there -- that engages the "stiffening mechanism" and you can adjust the shock -- then undo it.
It's only troublesome the first time - after that it'll be easy. I never tried it with the shocks already mounted & wouldn't want to - if they are, you might unhook one end to make it easy.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-04-2005, 12:17 PM
