Need Strut info for Sport Struts
I have a 74 911 with the Koni sport struts. I dont know how to adjust them and I cant find anything in writing to explain how to do it. There is no knob at the top like the other KONI shocks.
Signature Phrase " CATCH ME IF YOU CAN" 1988 Porsche 930 "Squerly" Built by "Porsche Doc" -------------------------- 1974 Porsche 911 (2003 - 2012) 2000 Boxster S (2006 - 2008) |
The old koni,s were adjusted by unhooking the top and bottoming the rod in the housing and then turning . It is best done before an installation as it is quite awkward when installed. The rears are a little simpler to get at but still awkward.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
a visual for you - there are some side projecting tabs or dogs on the bottom -- you need to turn it until they line up with some recesses and then push harder to seat them down in there -- that engages the "stiffening mechanism" and you can adjust the shock -- then undo it.
It's only troublesome the first time - after that it'll be easy. I never tried it with the shocks already mounted & wouldn't want to - if they are, you might unhook one end to make it easy.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
