-   -   where to get 11 blade engine fan for 3.2? (http://forums.pelicanparts.com/porsche-911-technical-forum/254633-where-get-11-blade-engine-fan-3-2-a.html)
76carrera3.0 12-05-2005 07:26 AM
Try Einmalig.com I checked with them in October they had them used then at $325.00
JeremyD 12-05-2005 08:03 AM
You know - I was helping a buddy try and find a used one several months ago and thought to myself that this would be a great opportunity to have one made out of CF or composite as well as the fan shroud.
As these things fail, there is going to be a market for them.
Wil Ferch 12-05-2005 09:54 AM
964 curved fans push about 65% of the flow that the earlier straight edge blade fans do...
caveat emptor ! ....
- Wil
adomakin 12-05-2005 10:50 AM
4595346080 is the ebay item number. its co.uk not .com
safe 12-05-2005 12:09 PM
Don't an earlier fan and housing fit?
David 12-05-2005 01:19 PM
I believe 80 to 89 911 and 78 to 89 930 are the same 240mm fan.
safe 12-06-2005 12:26 AM
So all fans from 80 are NLA?
David 12-06-2005 05:17 AM
I don't think they're officially no longer available, but it seems they haven't made any new ones for a while.
armandodiaz 12-06-2005 05:28 AM
Sent you a PM.
stlrj 12-06-2005 09:27 AM
Seems like a perfect opportunity for JB Weld.
safe 12-06-2005 11:35 AM
Are they all made of magnesium?
Can they be made of aluminum instead?
If someone works (or has a friend that do) at a foundry I bet they can be made.
David 12-06-2005 11:41 AM
Vertex makes an aluminum one. I don't think JB weld is out of the question especially if you prepare the notch surface correctly. The density of hardened JB weld is probably similar to magnesium.
rob justice 12-06-2005 02:16 PM
There's one on UK e-bay just now - sitting at £5.
For some reason the links not working.
Looks pretty good condition also.
Search by typing in Porsche 911 and its in the car parts.
