Could someone show me where the throtle adjustment is?
I know there is a way to adjust my throtle so it opens 100% at WOT. I cant seem to find the location of the correct link to do the adjustment at. Does someone have the location and maybe a picture of it.
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
RETIRED
On the side of the throttle body.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Picture? I looked but it looks like it's a bar with no adjustment.
The push-rod under the pedal is adjustable as well.....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Detached Member
So is the cable underneath the car if I remember. Have someone push the loud pedal and see what moves underneath.
Hugh |
Keep in mind I had my motor droped twice this year for some work, I assume when it was re-installed they might have slighly adjusted the throtle link. ( I noticed WOT was not as strong when I picke dup the car, but then again I had not driven it for 2 months since I droped it off at the wrench)
Crotchety Old Bastard
Maybe your wrench is trying to tell you something.............
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
RETIRED
When I did my 3.6 conversion I cut the stop block out from under the pedal. Got another 3/4 inch of travel.....might NOT be the same for your 3.2 but if your adjustment at the TB is maxed out.....look under the pedal.
Often the throttle linkage bushings (#2) on top of the engine are worn out and will cause the loss of WOT.
It is not uncommon for a 3.2 to have a throttle that does not open all the way. ...
Cheers
There should be a rubber bellow surround the linkage at the engine firewall / tunnel. You'll find it. It may be just above the tranny crossmember, which complicates things a bit. There is at least 1/4 inch of adjustment there with the two ball and socket rod ends. If you are not even getting to WOT, you may not even be out of closed loop mode on your DME. WOT throttle mode offers a richer mixture and considerably more power potential. Fix it ASAP! Doug
1971 RSR - interpretation |
I think I'll go by DeVitto's during lunch and ask him, DW SD - What your saying makes sence, I might try the cable at the end of the tunnel too.
disband
there are nylon bell cranck bushing that wear (go away) on the SC linkage that caused that on my car. i would imagine the 3.2 has them in there too, maybe check them.
replacing those bushing was a huge diff.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Went to DeVitto's today and he said my throtle is opening only about 80% of the way, he couldnt do anything about it till next week.
So where is the BEST place to make the adjustment at? So far I have gotten 3 suggestions.
Under car, on driver's side of transmission I believe. Ken
