Alright....
Weight of 3.0 engine & trans on pallet
Can anyone who has shipped an engine recently tell me the weight of a 3.0 long block & trans on a pallet?
And perhaps suggest the cheapest way to ship from TX to CA. THANKS!
Stephen Friendswood, Texas '78 Targa w/ '86 930/20 w/ '74 915/06 |
I shipped a 3.0 complete with injection and exhaust from Las vegas to Oregon recently...weight was around 600 lbs in a hefty plywood crate. Cost was about $200 through an outfit called Freightquote.com...find them on the web, highly recommended...ask for Casey.
"not an expert, but I play one on message boards" |
Alright....
THANK YOU!
I gave'em a call and it will be $215 from TX to CA via Central Freight. Thanks again.
Engine is a bit over 400 lbs: maybe 420; 430? SC trans should be about 135 lbs. You definitely want to protect the top of the engine with 40 lb or so of wooden crate.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
forwar air did it for me and it cost about 125 for just the engine(maybe less I forget) but they dropped it off at the airport depot and I picked it up at the airport depot. Worked out well.
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
I've also used Forward Air for big stuff. It's depot to depot, but they're good.
I've also used Orbit Freight and it was a nighmare.
