clutch problem
Hi,
Today while driving, i heard a pop and the clutch pedal went incredibly stiff, and won't travel very far. The car is still driveable, as you can just push it past the friction point i think, and the clutch isn't slipping when the pedal is fully up.
I immediatly assumed, helper spring, and thats what i'll be checking first thing tomorrow. But while i was driving home, there were a few moments when i went to press the clutch pedal and everything was back to normal, and then i'd press again and its back to stiff... could a broken helper spring go back to normal again?
Potentially what else could it be?>
Thanks alot,
Adam
_____________________
'73 RSR Interpretation
Old 12-12-2005, 04:24 AM
Ok, I checked underneath, and yep, the helper spring is snapped. So i'll be replacing that. But the clutch still goes back to normal every so often. Could something else be broken too?
Please help guys!
Old 12-14-2005, 05:33 AM
mschuep's Avatar
I'd replace the spring, most likely your problem if it is snapped, and relatively easy to replace. Next thing I would check is the clutch fork, maybe one of the arms popped off.
-Matt
1985 Targa
Old 12-14-2005, 08:27 AM
is the clutch fork under the centre console area? I'm not familiar with that term...
Old 12-14-2005, 08:34 AM
mschuep's Avatar
The clutch fork moves your throwout bearing in and out on the input shaft of the transmission, and you really have to do an engine drop (or at least a partial one) to get a look at it. Take a peek at Wayne's article on clutch replacement for some good general info and pics on clutches.
I suggest trying just the helper spring first, because much of the clutch assembly is inaccessible with the engine in.
-Matt
-Matt
1985 Targa
Old 12-14-2005, 09:16 AM
Unregistered
sammyg2's Avatar
I also suggest taking a picture of the broken helper spring BEFORE you take it off.
I always seem to scratch my head and turn the darn thing every way possible before i figure out the correct orientation and I've installed one several times. One time I got so frustrated I almost got out the manual and read the directions. Almost.....
Old 12-14-2005, 10:06 AM
Just incase people find this thread in a search, it turned out to be the helper spring.
Old 02-01-2006, 06:19 AM
Patton's Avatar
Just curious to know, my car never had a helper spring. My clutch seems normal, a little stiff. Is this a problem?
Patton
No Porsche at the moment but give me 6 months and then......
Old 02-01-2006, 06:39 AM
jeff1hughes's Avatar
The 930 uses a different transmission, I don't believe it has one.
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 02-01-2006, 06:41 AM
rallyracer's Avatar
87 should have a hydraulic clutch. The helper spring in part of the cable clutch mechanism on earlier cars.
1983 911SC-Sold!
Old 02-01-2006, 07:01 AM
Patton's Avatar
I have a 3.4 engine and an early year 915 tranny in a 930 body.
Patton
Old 02-01-2006, 07:14 AM
