Vin-barrett's Avatar
Question returning Weltmeister short shift back to stock
The PO of my car installed the Weltmeister short shift which I'm not too fond of.
I do have the original shiftlever.
Is this all I need to return to the stock shifter? When I see the WSS kit advertised it looks to only include a lever , spacer and hardware.
Could I just remove the spacer and replace the stock lever to return the car to stock? Or is there something else I need as well?
Maybe the stock hardware (shorter bolts)?
Vinny
-Vinny
1983 911SC
Old 12-15-2005, 06:15 AM
You remove the spacer plate and reinstall the original handle. The longer bolts should probably work (extra length will hang into the tunnel about 1/4 ". If I recall the hardest part will be transferring the shift knob without damage. Then reset the shift linkage at the swivel connector would be recommended.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 12-15-2005, 07:18 AM
Thanks for the reply John.
Looking forward to getting that thing out of the car (and adding a Seine gateshift).
Vinny
-Vinny
1983 911SC
Old 12-15-2005, 07:30 AM
911FL's Avatar
I did this on mine and had to cut the rear bolt down to fit properly. Otherwise it was hitting and binding the linkage leading to the rear.
Dan
“Out on some Sonoma County road, with Jimmy Dean and Steve McQueen”
1984 Carrera Targa
Old 12-15-2005, 07:34 AM
Thanks Dan
I will certainly keep that in mind.
Vinny
-Vinny
1983 911SC
Old 12-15-2005, 07:39 AM
