chrome vacuum plating sources?
We have a client that just has to have a chromed Carrera emblem to match the chrome anniversary 911 emblem. Since we can only get black plastic from Porsche, the obvious thing to do is get it vacuum plated. What sources are out there that anyone has had experience with?
Thanks! |
hemmings has a few plastic platers listed.
all of the chroming i have had done for other application has been done by classic components in california. i think they can do plastic now but i have never had a plastic part done.
Dave: Give Astro Plating in Van Nuys a call. If they can't do it, they might be able to refer you to someone else.
Also, here's the link to Classic Components: http://www.classiccomponents.com/plastic.htm Good luck!
1984 Targa Last edited by scottb; 12-13-2005 at 03:53 PM.. |
I would rather be driving
HMM I wonder if the e-beam gun is still hooked up in the chamber at work? I have a Chrome target.
Depending on the type of plastic it may or may not stick. Although Chrome sticks to many things and is often used as an adhesion layer for other metals. Sorry to be thinking out loud...
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Make My Day
There are company's that specialize in chrome plate plastic, here's one near me.
http://www.4gsp.com/pages/index.htm
74 911S Targa ROW Building Designer/Business Owner |
Astro does not do it- we already asked. Thanks for the tip on hemmings and the n.y. outfit- will check both
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Dave: Classic Components is in Santa Ana. They look promising!
Good luck! Scott
1984 Targa |
Wildman Emeritus
Try AAA Plating in Compton or EmbeePlating in Santa Ana.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
just got off the phone with a friend that makes the nameplates for Ford. Here is the skinny on chroming plastic. Though the initial product would look stunning, he points out that exterior use of this would lead to its early demise. The ever so slight differences in the expansion rates of the metal plating and the plastic substrate would result in early failure. I.e- it would fall off , crack, peel- all of the above. Given that this process would be at least in the $100 range and up (he pays 300 for each prototype they make before manufacturing in metal) this would be a costly and possibly short lived experiment
I think we need to find someone that can pour them in brass, then we can get them plated the "right way" so it lasts a lot longer thanks for the help guys- i have a shop in mind that may be able to pour brass will post my findings then So now a new thread
