Ball Joint Removal Tool - Loaner?
Anybody in the Holiday mood interested in loaning out their Ball Joint removal socket for a couple weeks? I am reluctant to spend $50 on a tool that I will use once knowing that there are a bunch of Pelicanites that have one sitting in their tool box? I am reliable and will gladly place a deposit (or replace) if something happened? Any takers??
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Once a friend of Cliff
the removal is best done with a pipe wrench and getting new castle nuts for the reinstall. they freeze on and you WILL more than likely ruin the socket by trying to use it for removal. just my two cents from my past experience.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Irrationally exuberant
What Toby said only get a BIG pipe wrench.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Ahh, Toby is just hamfisted...:-)
Sorry Toby, I couldn't resist. More to the point, if you have a later model Carrera, the castle nut is recessed to the point of not being able to get a pipe wrench on the nut. I recall a post where one of the guys fabed an easy to make tool which work well for the removal of the nut without buying the $50 tool. You may want to do a search, as I cannot recall who posted the home made unit.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Loaner Tool.....
Vance,
Do you have access to an impact wrench? I have a home-made tool for ball joint removal/installation. ![]() ![]() Installation and final torque (180 ft-lb.) applied with this tool. Contact me at ATD911@hotmail.com and will discuss delivery. Season's Greetings To ALL !!!!! Tony |
I recommend a dull chisel (completely dulled) and a sledge hammer. Apply to the castle nut, smack with hammer (or use an air chisel if you are so equipped) and the nut WILL come off.
Works well to install also! Chris
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
I saw the homemade unit and if it is the same one, it was made by Chris Streit. I already removed the one nut with a tool from one of the local wrenches and it came off very easily - so I am confident that I can reuse the nuts and I won't ruin somebody's tool. I just wanted to avoid taking my A-arm to the local wrench when I wanted to remove and install - but it beats $60 for the tool?
I took my a-arms off and my mechanic/friend zapped them off using the right tool and an impact gun in less than 30 seconds. If you destroy the rings with a chisel or pipe wrench you aren't saving much money.
Friend of Warren
Here is what I used. Don't blame me if you die for not using a Porsche approved tool.
4WD Axle Nut Socket
Kurt V No more Porsches, but a revolving number of motorcycles. |
FYI, the nut is not destroyed when using a "DULL" chisel (or a large brass punch). I have had less luck getting frozen nuts off older cars with the proper tool (even broke one trying).
Just a reliable, inexpensive and fast tip...
Tony - Thanks for the offer! I sent you an email.
