-   -   Color Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/256143-color-questions.html)
Lynn-75 12-14-2005 10:17 AM
Color Questions
Hi,
I have a 1975 Porsche 911 Cabriolet that I'm considering to re-paint.
Can you match either of these colors?
Can you recommend a shop or shops in the Washington DC area?
Lime Green
Metallic Azure Blue
http://forums.pelicanparts.com/uploa...1134584218.jpg http://forums.pelicanparts.com/uploa...1134584237.jpg
Kemo 12-14-2005 11:22 AM
Lynn-75,
If you can get the paint codes for the color you want, the paint shop should be able to match.
Paintscratch.com is a pretty cool resource for getting the code of the color you want. The only blue close on their site is this:
Cobalt Blue Metallic Clearcoat - 2006 color - Code = 3C8/F6
and according to this thread
http://forums.pelicanparts.com/showthread.php?s=&threadid=251208&perpage=20&highl ight=viper%20green%20color%20code&pagenumber=1
Kelly, Viper and Emerald green have the same code - L225
I hope this helps. Be sure and post pics of the project. Is your 75 a targa converted to a cab?
Lynn-75 12-14-2005 11:49 AM
Hi Kemo,
Thanks for the info.
My car is a 1975, re-bodied with a 1987 cabriolet body and a 1985 3.0 engine.
Trying to figure out the right parts is a trick.
Thanks,
Lynn
Kemo 12-14-2005 12:03 PM
you must have got the moritz-max as opposed to the max-moritz ;)
good luck with your project and remember to post some good pics, if you can, along the way.
